Thread: Central power and ground???
11-15-2005 #1
- Aug 2005
- 48
I have a custom center console with 5 gauges, head temp x2, oil temp,trans temp, clock. 5 rocker switches and 1 momentary start switch. I am thinking about bringing power and ground to a central terminal under the console. I would then be able to go to these terminals for all the connections. Of course wires would have to go to the sending units, but power for the gauge lights and such could be tapped into right there on the central terminals. Has anybody done this, or have any suggestions. Thanks in advance!
11-24-2005 #2Well I would use a aftermarket fuse block for power. wrangler power product has ones up to 12 outputs. then for ground you can use the household ground blocks or find the aux ground block from a police cruiser. ( usualy mounted to the right of the gas pedal)
Tim89 Lincoln Towncar pro touring project ( new info found for handling)
95 Explorer XLT OFF-Roader
95 Chevy Suburban LT 4X4
07 Harley XL1200L Low 08 Harley XL1200N nightster
Would you vote for someone who doesn't stand up for the flag?
11-25-2005 #3I did something like that on my old pickup. I took a piece of aluminum plate, a ground terminal block and an insulated terminal block. One end of the insulated terminal block had constant power and the other had switched power, then I jumpered in from there to create multiple taps of each.
11-28-2005 #4
- Aug 2005
- 48
Thats kinda wnat I'm doing. We have installed a brand new painless wiring harness. Just went to an auxillary power source on the fuse block and brought it to a central location. JB Weld and a bolt on a block under the console and there you have it. Ground goes to transmission tunnell. We created a harness with 2 twelve pin terminals and 1 six pin terminal. Now the whole console panel with all guages and switches quick releases with three plugs for additions or repairs and simply access. I'ts working great so far.
Originally Posted by GetMore
I'll add some pics this when I get em...next day or so!
