    Results 1 to 2 of 2
      pedal does not get stiff
      I just installed a new drive train and finnaly got things started. Everything works great with the exception of one. I installaed a hydraboost with my drive train change and am having a horrible time bleeding the brake system. I have a wilwood master and previously had a vacuum booster and they bled fine with a fairly stiff pedal. The master has been bled properly. All that was done was the booster sway and the swap of one 4" line. The backs bled well. The front calipers seem to be a problem. I have even used a vacuum pump without success. I am assuming there are no pushrod issues. Any suggestions?
      Jul 2002
      Muskegon, MI
      DId you get ahold of Paul at Hydrateck??? I assume that is where you purchased the hydraboost so it only makes sence to get ahold of him first.
