    Results 1 to 1 of 1
      Feb 2016
      Lawrenceville, IL
      Ford 6R80 cooler manifold
      If any of you are looking for a solution to convert from your factory rigid tube cooler lines to a braided flex line we have a conversion manifold to give you that option. This black anodized, billet aluminum manifold incorporates a dual o-ring seal on each port and installs with the same bolt that secures the factory lines. The two line attachment fittings are a -6 AN male to give you the option of attaching a straight, 90 or 45 degree line fitting depending on how you will be routing the lines. Priced at $95 each and can be paired with one of our stainless or black braided line kits.https://bowlertransmissions.com/c/15...-6-an-fittings
      visit us on the web at www.bowlertransmissions.com
