09-18-2004 #1
New to Pro-Touring
- Sep 2004
- Wichita Falls, Texas
- 2
Low pedal after disc conversion...? HELP!
I am helping a friend with a front disc conversion on his `67 Nova.
We modified his drum spindles and used the rotors, calipers, hardware, etc...from a `70 Chevelle. He has manual brakes, so we used the master cylinder from a `75 Camaro with manual discs. All parts are brand new. The car stops fine and will lock the front tires up upon hard braking. What concerns us is that the brake pedal travels almost to the floor. It rests in the normal postion, but gets quite low when braking. These Novas did not use a proportioning valve and we are not using one either. I think this is our problem. If so, do we just need an adjustable valve in the system or must we use a factory type?
Any / all advice is welcome.
Thank You!
