    Page 2 of 4 FirstFirst 1 2 3 4 LastLast
    Results 21 to 40 of 61
    1. #21
      Jun 2016
      Evansville IN
      Quote Originally Posted by HotRod47 View Post
      As a body man and painter I would never start with something so bad. Not that it can't be done, but I just want to start with something a bit nicer and more solid. Good for you, and Tony for resurrecting a car that 99% of the car guys out there would walk away from.
      I would never take on anything like this without Tony's help.
      Believe it or not this was a better option to buying a new dynacorn body.
      Do you know Tony?
    2. #22
      Feb 2013
      Nice to see you saving the car! Hopefully I get to see it cruising around the area once you get it going!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    3. #23
      Jun 2016
      Evansville IN
      Quote Originally Posted by Josh@ridetech View Post
      Thanks. I would be excited if I could have it on the road in 2018.
      Been wanting to build a fastback for the last 20 years.
    4. #24
      Jun 2016
      Evansville IN
      Tony got it back from media blast and primer.
    5. #25
      Sep 2016
      LA - Lower Alabama
      I have to ask, why did you decide to resurrect this car versus buying a new shell and going from there?
    6. #26
      Jun 2016
      Evansville IN
      Quote Originally Posted by AU Doc View Post
      Great question
      The original plan was to convert my 66 coupe to a fastback but that would basically mean only the dash would have been used. Plus the coupe has some sentimental meaning to me and my wife.
      Before I had decided not to cut up the coupe, I had purchased this fastback with the intent to use the frame for the conversion.
      The decided why not make the fastback into a new shell and redo the coupe eventually.
      Believe it or not, this fastback will be cheaper than a new body and will be almost as good and have the original vin.
      Overall not the way I had originally planned it but it seems to be coming along better than I thought it would.
    7. #27
      Sep 2016
      LA - Lower Alabama
      I never would have guessed it would be cheaper to strip a car down THAT far vs buying a new stamped shell. Especially once you consider the cost of paying someone to do the body work. Seems like it would be easy to rack up $18k in parts and labor.
      I'm only asking because the wheels are starting turn on a next project, and body work is out of my wheelhouse.
      Thanks for the candid response!
    8. #28
      Jun 2016
      Evansville IN
      Body work is out of my league as well. Luckily I got tony doing it.
      When it is all said and done, I will have less than $18k for a new shell with doors, fenders, mini tub, deck lid, Shelby hood and front valance, 68 shock towers. This includes buying the original car and having everything delivered to me.
    9. #29
      Jun 2016
      Evansville IN
      Tony started putting together the frame rails. You can see the 68 notched shock towers and core support with the wider radiator opening.
      Hopefully see more progress this week.
Size:  327.4 KBName:  IMG_0990.JPG
    10. #30
      Sep 2015
      WOW. I applaud your willingness to bring it back. Cool to see this happening instead of scrap
      1966 Mustang Coupe
      5.0 EFI- T5
    11. #31
      Jun 2016
      Evansville IN
      Tony is making progress. Sent me pics of the DSE mini tub frame sections installed. Hope this allows for a 315 tire to fit like DSE says it will.
    12. #32
      Jun 2016
      Evansville IN
      Most of the floor is done
    13. #33
      Maryville, TN
      Quote Originally Posted by Wldtang View Post
      What's left after the car was stripped.
      This may be the saddest picture I've ever seen LOL
      Loving these old Mustang builds. Subscribed!
      Dan
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    14. #34
      Jun 2016
      Evansville IN
      Progress today. More pics from tony.
      He started test fitting the 68 towers.
      He had to use the 68 aprons (pictured in black) to get the alignment correct on the towers. We couldn't use the 68 aprons due to the 65 fender bolt holes not being the same. Once he got the alignment right, he installed the 65 aprons.
      Look at the clearance the 68 towers will give.
      Also the large opening of the 68 radiator opening.
    15. #35
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Great job. You going to take the opportunity to connect the front and rear sub-frames?
      1966 Plymouth Fury III
    16. #36
      Feb 2013
      Looking really good man. Are those the Dynacorn shock towers?
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    17. #37
      Jun 2016
      Evansville IN
      Quote Originally Posted by Godbolt View Post
      I will once I get it back. Thinking of using the DSE subframes that go thru the floor. May try to tie the rear lower control arms into the subframes
      - - - Updated - - -
      Yea
    18. #38
      Jun 2016
      Evansville IN
      A few more pics
    19. #39
      Jun 2016
      Evansville IN
      More progress
    20. #40
      Jun 2016
      Evansville IN
      A few more pics
