Thread: Priming process?
09-04-2016 #1
- Sep 2009
- Atlanta,Ga.
- 182
Priming process?
Can you all chime in on my priming process I want to use. Keep in mind I have to pay to get the vehicle towed to the paint booth. My compressor at home is only a 21 gallon Harbor Freight special.
Here is my proposed plan.
1. Finish metal work and the spray(scrub) phosphoric acid on rust spots and pressure wash off while acid is still wet.
2. Dry with lint free paper(shop) towels and sand with electric orbital sander 80grit. I also have clean and strip disc also.
3.. Tow to paint booth. Wipe clean with SPI waterborne W&G remover and then SPI Solvent W&G remover.
4. Spray body in 2 coats SPI Epoxy let sit for 24 hours in paint booth.
5. Spray 3 coats Evercoat Slicksand or if something is better do suggest it.
6. Tow back home to do blocking and filler work while using a guide coat.
7. The grits to use for the blocking procedure gets a bit fuzzy. I was thinking 180, 220 for the Slick Sand.
8. Tow back to paint booth use same prep procedures and spray with 2 coats of SPI 2k primers. Tow back home and block . Not sure on exact grits but want to finish with 600 grit wetsand. Color is Ford Dark Shadow Grey.
For epoxy and 2k primer I have the HF Professional set.
The SlickSand(or similar) will be sprayed with this https://www.amazon.com/TCP-Professio.../dp/B001NOU92G
I will be buying a Iwata LPH400 for base/clear
I am SUCH a rookie to Pro-Touring
