    Thread: Hood question
      Feb 2014
      SoCal
      Hood question
      On my 67 gto I have to push the hood down in the back after its closed to get it flush. Anything I can do to remedy that?
      Mountain Springs, Texas
      Original hinges and springs? Have you tried adjusting the hinges?
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2014
      SoCal
      Hood question
      Not sure. I would assume stock hinges and springs. I may be max out door adjustment in the rear. I check when I get home.
      Quote Originally Posted by keith4909 View Post
      To lower the rear of the hood you raise the front of the hinge if I remember right. Counter intuitive....
      Don
      Jonesboro, Arkansas
      You can also lower the rear of the hinge. This will bring the hood closest to the cowl, down. It will bring the hood closer to the cowl, not a lot, but some.
      Carl Wilson
      Oct 2010
      Sacramento, CA
      If you mean that you physically push the rear of the hood down after closing it, then your hinges are dirty, gummed up, or have paint in them. Take some teflon dry lubricant spray and spray every pivot point, then move the hood up and down a dozen times and see how that goes.
      Rick
      Rick - 1969 Camaro - LS1 driven daily
      Oct 2012
      I had the same issue. Loosened the bolts closest to the firewall and pushed the hood up to lower the back of the hinge. Helped a bit, but ultimately I had to buy new hinges to solve the issue.
