      Nov 2012
      ocala fl
      approximate torque and horse power
      I would like to know if someone can give me an approximate what torque and horsepower my engine has. It is a 454 Chevrolet motor bored .030 over with a eagle 1/4" stroker crank kit and 10:1 compression. It has a set of old closed chambered passenger car heads that are ported to the max and the largest valves possible. The cam is a Comp Retro roller complete kit with 230/236 and 510/520 lift and steel roller rockers. I run a 2 1/8 Hooker comp headers into a complete Pypes violator exh system. I have a Weiand tunnel ram with 2 4 bbl holly throttle bodies and a holly PH EFI with 8 injectors [1000 hp?] in the tunnel ram. Distributor is a stock efi out of a chev pickup and a MSD coil.
      My running gear is a centerforce steel flywheel ram hd clutch with hydraulic clutch. TKO600 trans steel drive shaft with 1350 u joints, Moser 9"" ford with 350 posi and 275/40r17 25.5" tall tires.
      My problem is my clutch slips in 5th gear at 15/17oo rpm.
