    Page 10 of 11 FirstFirst ... 5 6 7 8 9 10 11 LastLast
    Results 181 to 200 of 203
    1. #181
      Vancouver, BC
      Stock 6.0L LQ4, TC76, T56, hope to be on the road real soon...
      1972 Nova, forged LQ4 with twin 6466's, T56 Magnum, OEM subframe w/ Speedtech front, Chassisworks gLink rear, Ridetech coils & Wilwoods, with a rear floater in the works --> http://www.ls1tech.com/forums/conver...1972-nova.html
    2. #182
      Aug 2006
      Oakland, CA
      LQ4, T56 and a Precision 7675. It's 99% done.
      1967 Camaro
    3. #183
      Feb 2002
      Springfield, MO
      Sweet!!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
    4. #184
      Aug 2011
      Clearwater/FL
      I just picked up a garrett off a 06 6.0 powerstroke, anybody got specs on these things??
      88 Blazer sbc
      05 300c
    5. #185
      Cartersville, GA
      I just started my "Project GNXcess" 1983 Regal T-Type. Its getting a forged 408 (LQ4 based) with twins, and a T-56. I'll post pics when I have something to show other than teardown!
      Joe Hinds
    6. #186
      Sep 2008
      Kathleen, GA
      64 Chevelle LS1/T56 turbo project in progress hope to have it done by March
      stock shortblock LS1 (9.6:1 comp)
      TC78 w/ 1.05 A/R
      ported #317 heads
      twin Walbro 255 (second pump on a 5psi Hobbs switch)
      -8 AN feed
      -6 AN return
      3" intercooler
      #80 SD injectors
      will run E85
      Turbo is in:
    7. #187
      Jan 2007
      Hi
      WWW.SPEEDINC.COM 1957 Eldorado Brougham.......in progress
    8. #188
      Nashville, TN
      Oh now this is my type of thread. :D
      - Matt -
      '69 Camaro
    9. #189
      LI New York
      Finished.....
      1968 Camaro Convertible. 9" rear, Caltracks, 350 , PTC 3000 stall, Custom Twin turbo built by ME.
    10. #190
      Sep 2002
      So. Cal
      Hidden Turbos....Hot of the press..49 miles and counting
      370 LQ9, Forged Piston and Rods, AFR 215 LSX heads, Edelbrock Airgap manifold, GM Distributor conversion, Twin Garrett GT2871 turbos with .86ar turbine housings, Air/Water Intercoolers (still needs water plumbing).
      There they are!
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
    11. #191
      Chicago
      Okay first off how the heck did you do a motor swap and all of the fab without hurting the engine bay.
      second - Simply Awesome looking
      Quote Originally Posted by RSX302 View Post
      There they are!
      marty-mj
    12. #192
      Sep 2002
      So. Cal
      Thx Marty
      Turbo installs are always lots of creativity, patience & staring at it with a beer in hand for many hours! Many times asking "Where do I run this, how do I get that in there, What if I move that"
      It did require new motor mounts and repaint of the front clip. Engine is 1" further forward due to longer input shaft and 1.5" taller then the SB Ford. Dry sump system help too. No crossmember issues to deal with.
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
    13. #193
      Chicago
      Thx Marty
      lol - I remember doing that with Dave over at Comp Fab when we were working on my truck. However I was drinking Ice Tea had a small problem with the Liquor. Once we cut out the firewall it was so much easier to do.
      You need to post some more pictures
      marty-mj
    14. #194
      Sep 2002
      So. Cal
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
    15. #195
      Chicago
      Thanks for the link - Looked at all of the pictures
      marty-mj
    16. #196
      Jan 2000
      Thousand Oaks California
      Quote Originally Posted by mnm99 View Post
      Hey Larry. I spoke with you a few times about your build. I finally finished it. Here's my 15 pounds in a 5 pound sack...LOLAttachment 43848Attachment 43849Attachment 43850Attachment 43851
      How are things going on your ride? MotiV8r is going through a change. It's at JCG and a Holley Stealth Ram is going in.
      Larry Callahan
    17. #197
      May 2009
      Elkhart, IN
      Now this is the proper topic for pro touring, not lets see how big your rims are, lol.n These are sick cars.
      Lots of Neon's
      Harley NRS
      Trx250r
      69 Camaro: Under Construction Small Block (Soon LSxT)
      http://www.cardomain.com/id/teamvpneon
      Used to be known as teamvpneon
    18. #198
      Nov 2011
      This is a great thread. Ill try posting a few pictures of my hoop-ty. It's a 1970 chevelle, world products block/383ci, AFR's and a MPGT45 turbo, Tremec TKO and a 9 inch. My original goals were a 10 sec. quarter mile time so thats the direction I started heading with it. Well after I was introduced to this site a few months back I really want to build something that handles. I'll be adding some things here and there to my current build to help with handling but I need to stick to one path and just finish the damn thing. anyways- hoping for 600rwhp which I don't think should be a problem. Hope you people like it:
      Doug
      1970 chevelle, carb'd, turbo'd 383ci with a tremec tko.
    19. #199
      Nov 2011
      another, 3.5" down pipe to full 4" exhaust.
      as you can see this picture is different than my first. I changed the routing of the down pipe for clearance issues.
      Doug
    20. #200
      st. paul mn.
      here is my project taking all my time.twin 57mm on a 5.3 hope to have it on the road in a couple of weeks.
