    Results 1 to 9 of 9
      May 2008
      Chicago
      ESAB welding Wire for Stainless
      I don't know if this is allowed here, if it is not please let me know and I will remove the thread. I just thought I would pass this deal along to some of the fabricators on here.
      I have three 33 lb. spools brand new in the box. This wire is used to weld stainless as listed below from the ESAB website. I am asking $300 for all three or $100 dollars each box. That is less than half price, these retail for $240 per box.
      I also have 33 lb. spools of Mig-6 wire as well for the same price of $100 each.
      Shield-Bright 316L X-tra was developed for the welding Type 316L stainless steel and also can be used for the other stainless steels including Types 316 and 304L. Shield-Bright 316L X-tra was developed for welding in the flat position and for horizontal fillet welds with flat to concave beads with excellent slag removal.
      Jan 2010
      Delaware
      what thickness is the stainless wire?
      1973 Trans Am 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods, 77mm Garrett turbo and methanol injection. 1064hp at the flywheel@5500 rpm
      May 2008
      Chicago
      1/16 or 1.6mm
      Jan 2010
      Delaware
      Hmmm. I'm Used to seeing it listed as a decimal. Like .030, or .035
      May 2008
      Chicago
      1/16 converted comes out to .0625
      Jan 2010
      Delaware
      The big spools fit in my machine, but as far as I know its only capable of .035 wire max.
      May 2008
      Chicago
      Ok I am just trying to pass along a good deal. I can't use this wire but I thought someone on here may be able to.
      Jan 2010
      Delaware
      No...not knocking it at all. Just sorry I cant use it. lol
      May 2008
      Chicago
      I know that. Wish you could though
