      Dec 2015
      1970 Challenger to.......
      join my 1966 GTO as a stablemate.
      my name is Christian, just bought a beautiful 1970 Challenger to share garage space with my 66 GTO, hope to have it home in a few weeks, here are the specs/build
      1970 DODGE CHALLENGER
      This car was featured in Popular Hot Rodding Magazine and was built by South Coast Rides in Texas. The car received a full rotisserie restoration with the underside as nice as the top. The 416 stroker small block was built by Hughes Engines in Illinois and made 555 hp at 6,100 rpm and 552 lb-ft at 4,600 rpm while carbureted. The engine has since been converted to fuel injection. The car was previously equipped with an air ride suspension but that has since been removed for a QA1 coil over setup on all 4 corners. This is a well-sorted pro touring style car that goes as good as it looks.
      ENGINE
      Type: Chrysler 416ci small-block
      Block: Chrysler block, bored to 4.080 inches
      Oiling: Melling high-volume oil pump, Milodon pan
      Rotating assembly: Mopar Performance 4.000-inch steel crank, Scat H-beam rods, Keith Black 9.3:1 forged pistons
      Cylinder heads: ported Edelbrock Performer RPM aluminum castings with 2.08/1.60-inch valves; Hughes springs and retainers
      Camshaft: Hughes 242/246-at-.050 hydraulic flat-tappet cam, .592/.606-inch lift, 110-degree LSA
      Valvetrain: Hughes lifters, 1.6:1 rockers, and timing set
      Induction: ported Edelbrock Victor intake manifold, FAST XFI Fuel Injection
      Ignition: FAST billet distributor, 6AL ignition box, coil, and plug wires
      Fuel system: Rick's Hot Rod Shop tank; Aeromotive in-tank pump and regulator
      Exhaust: TTI Performance 1�-inch long-tube headers and X-pipe, dual 2.5-inch DynoMax mufflers
      Cooling: Mopar Performance pump; Be Cool radiator and dual electric fans
      Output: 555 hp at 6,100 rpm and 552 lb-ft at 4,600 rpm
      Built by: Hughes Engines (Washington, IL)
      DRIVETRAIN
      Transmission: Phoenix GM 4L60E overdrive, adapter plate, custom flexplate, and 3,000-stall coverter; Compushift computer, Lokar shifter
      Rear axle: Chrysler 8 3/4-inch rearend, Auburn limited-slip differential; Moser 30-spline axles and 3.70:1 gears
      CHASSIS
      Front suspension: ridetech tubular control arms, QA1 Coil overs; stock sway bar
      Rear Suspension: Ridetech four-link, QA1 Coil overs, and subframe connectors
      Brakes: Baer 13-inch discs with two-piston calipers, front and rear
      WHEELS & TIRES
      Wheels: Boze Pro Touring 18x8 (4.5-inch backspace), front; 18x10 (5.75-inch backspace), rear
      Tires: Goodyear Eagle F1 225/45R18, front; 295/45R18, rear
      Apr 2014
      DFW, TX
      Those are two really nice cars to have in the garage... What is your plan for figuring out which one to drive?
      1978 Pontiac Trans Am Y88-R,
      UMI Performace, LS3/T56 Holley EFI
      Dec 2015
      Quote Originally Posted by gscherer78ta View Post
      waiting on the challenger, but i think i will rotate, thats what i do now with my others
      Aug 2013
      A beautiful pair to draw to.
      Nice!
      Dec 2015
      thanks guys, i am loving the challenger
      2015 Porsche Macan Turbo (white)
      2015 Porsche 991 Turbo S (agate grey)
      1996 Porsche 993 Turbo (guards red)
      1970 Dodge Challenger (B5 blue)
      1968 Porsche 911 (sand beige)
      1967 Vette (elkhart blue)
      1966 Pontiac GTO (light blue)
      1966 Fastback (black)
