    Results 1 to 9 of 9
      Jan 2015
      Belgrade MT
      76mm turbo lq4 69 Camaro
      Ok Fellas, updated post:
      I finished up the 70 LS1 Swap, turned out pretty good.
      Now I am on to my 69 that I had planned on putting a 60K mile 5.3 in but i broke the balancer bolt off in the crank shaft, so now it's got my 130k mile 6.0 in it. I need your guys thoughts on a couple things, here's what I currently have done:
      1969 SS Camaro
      fresh 12 bolt posi w/ 3:73, welded axel tubes, bigger axels.
      beefed up driveshaft and u joints
      2004 LQ4
      stock 317's with fresh valve job
      LS6 243 .550 valve springs
      trunion upgraded stock rockers
      04 LS6 5308 Camshaft
      trick flow 7.425 pushrods
      ARP head bolts
      LQ9 Headgaskets
      Melling 10296 oil pump
      Holley 550-602 HP Efi
      LS1 intake manfold, stock tb
      60# injectors
      LS2 timing chain
      Stock t56
      Stock clutch
      I need advice on whether or not my 76mm On3 turbo is going to work for this motor. I have been told that it will be too small for my displacement and will make a bunch of noise but no power. My HP goal is 500-600 to the rear wheels and daily driver compatible.
      I will be making my own turbo manifolds out of stock ls manifolds, probably a stock LS1 f-body drivers side for pas side up and forward, and a trailblazer ss passenger side down and forward(drivers side) because it has to go under my remote power steering pump pulley.
      I also need advice on what turbo parts would be a good fit for my build:
      Intercooler
      hotside and coldside piping diameter
      wastegate
      bov
      what clutch to run
      build or don't build trans now?
      anything else i might be forgetting?? thanks fellas.
      here is the car as it sits now.
      '69 ran 9.10 @ 82 mph in 8th mile on NItto Invo street tires at Sturgis SD Speedway the last weekend of June 2015.
      1969 Camaro LQ4/T56
      Jan 2015
      Belgrade MT
      anyone?
      1969 Camaro LQ4/T56
      Jan 2015
      Got a very similar build I am working on at the moment. Just curious if you ended up going with the set up you posted? and how well did it work out? any info would be awesome.
      thanks man!
      Jan 2015
      Belgrade MT
      Quote Originally Posted by ejh532 View Post
      thanks man!
      Yeah dude, actually under way with the turbo build. Took me a minute to aquire parts for the build. I've got a build thread going over on LS1 tech right now. Basically, at this point I've got my hotside all tacked up, turbo mounted, ic set in the car tonight. Waiting on fuel lines, coldside piping, and other misc parts. I'll try to keep this post updated. Here's some pics of the progress.
      https://goo.gl/photos/doHGr3zxJ1frWuFU6
      Hit me up if you have any questions. Next I need to get my wg mounted in the merge, get the coldside built, redo the fuel lines, rails, and regulator, put in my new clutch... basically I've got alot left
      1969 Camaro LQ4/T56
      May 2015
      Island Lake, IL
      If it's too small, you could pick up another turbo.
      From what I've looked at with regard to these turbo's, it's mainly the exhaust side that's "small" for V8 engines but don't take my word for advice. I'm not a turbo professional. A lot of people say stuff that spreads like wildfire on the internet like it's actual fact. These On3 turbos were mainly designed for mustangs and camaro so you should be fine.
      Jan 2015
      Belgrade MT
      Quote Originally Posted by F-Body International View Post
      Right!? So true!
      Question for anyone following: I am running the Holley Hp Efi 550-602 standalone setup and am wondering what I need to get from Holley to utilize the built in boost control function? Is there a boost solenoid, aux harness, ect. Thanks in advance!
      1969 Camaro LQ4/T56
      Jul 2011
      Prescott, AZ
      Progress looks great! What A/R is the hot side of your turbo? Also what clutch setup did you end up going with?
      Jan 2015
      Belgrade MT
      .96ar hotside, .80 coldside I believe, I ended up snagging a cermaic Monster clutch off the forums with 300 miles on it. Single disk rated at 850hp so it's probably gonna chatter like a mo fo, but I'll make due until I can afford a twin disk.
      1969 Camaro LQ4/T56
      Jul 2011
      Prescott, AZ
      Quote Originally Posted by snowhunter87 View Post
      If you decide to go dual in the future, give us a shout!
