Thread: TH400 flex plate gap
03-06-2016 #1
- Aug 2004
- San Bernardino, CA
- 883
I test fitted my 10" speedway torque converter to my LS/th400 combo. The converter plugged into the trans just fine, two clunks on the input shaft. what do you all think of this gap? its about .20, i stacked all the washers from the ARP bolt set i have and its a perfect fit. do you think i should use all 3 washers or just 2 washers and pull the converter forward a bit? Im using 7/16 x 1.25" ARP bolts. i need to order more ARP washers.
