    Page 18 of 36 FirstFirst ... 8 13 14 15 16 17 18 19 20 21 22 23 28 ... LastLast
    Results 341 to 360 of 1089
    Thread: Cuda at SEMA
      Jan 2003
      Arizona
      G-Force Cuda works for me.
      What will you run for wheels and tires at Maxton? How big are dem brakes? Will you change the gearing? Is the car running yet? Have you driven it? Why do cows sleep standing up?
      ________________
      Steve Chryssos
      Nov 2004
      NW Arkansas
      Quote Originally Posted by streetfytr68
      whats funny is bob will probably amswer that?
      KENNY DAVIS HOTRODS
      Jan 2003
      Arizona
      Quote Originally Posted by Travis B
      I'm sure.
      ________________
      Steve Chryssos
      they have approved the tires and wheels that are on it. We're talking to BBS about some wheels for competition. The tires that are on it are rated over 200..they come on Carrera GT's. Brakes are Red Devil 15" front and rear..ceramic coated titanium rotors..gearing is fine..342 with a .73 6th..waiting to get the rear end back..Rockland didn't have the housing for the over 3 ratio gear set,,I had to take mine out and send it to them..We are installing the computer etc now..not driven yet... I don't know much about cows..I'm a sheep man myself. Goats if I want some strange
      Nov 2004
      NW Arkansas
      Quote Originally Posted by Bob Johnson
      lol......bob thats hilarious
      glad to hear you guys are getting it assembled again. Have you heard it run on the dyno or anything yet bob?
      KENNY DAVIS HOTRODS
      Canton, GA
      Maxton cage rules
      Hey Bob, it may be somewhere in this huge thread, but I have failed to find it if it is.
      What is Maxton saying about the cage rules for a 200mph plus run? We are using a full chrome moly cage/less door bars in our Sixtynine. Diameter/wall thickness?
      Is your cage chrome moly or DOM?
      Mark
      www.evolutionmusclecars.com
      Nov 2004
      NW Arkansas
      Quote Originally Posted by evo69
      Mark
      hey mark....this is from memory so bare with me and i'm sure bob will elaborate when he gets back from barret jackson
      They made there cage out of 1.5 tubing and sleeved alot of it with 1.25 where they inlayed the carbon fiber. The only main concern they had with there cage is that the main hoop was not 1.75. I'm bob will be back on here after the barret jackson
      KENNY DAVIS HOTRODS
      maxton cage rules
      Mark
      All cars over 175 MPH must have a full roll cage of 1 5/8" x .120 wall. Door bars are a must have along with a lot of other details.
      5 or 6 point seat belts, window net, exterior door release and master power switch, parachute, 10lb fire system for driver 5lb system for engine, window tabs front and rear, two roof rail strips 1/2" to 3/4" tall, racing seat mounted directly to chassis. I can try scanning the check list and chassis specs if you need them . The cage in the Cuda is 1 1/2" DOM
      Bob what was wrong with the main hoop that was in the car? Was it the carbon fiber inlays the reason?
      carbon inlays were OK since we pressed a 1 1/4 tube inside it..Main hoop requires a
      1 3/4 OD 120 wall tube..ours was 1 1/2 120 wall. we will put a bolt in 1 3/4 beside the other..the rest was OK
      Mar 2003
      Make it big
      any info on how the sectioning was done on the cuda? I read the post alan did, but i'm confussed on where it was cut on the main shell.
      -David
      I emailed Alan to give you an answer. I contacted Jeff Isaacs to put his Camaro on the site..he's going to try tonight. I have a friend over here that's doing a 65 Fastback Mustang for a celeb..put an 04 or 05 firewall and floors, with one of his front ends and a 05 straight axle Mustang rears..going to run a mustang mod motor..just not sure which one..gonna have abs and traction control..it's kind of a secret..he will post on here shortly..this guy is pretty dang cool..Steve, call me I want Johnny Hunkins to get this car. I just found out about it..it'll be neat...I know Johnny's out of the country
      sectioning
      Quote Originally Posted by F70t/a
      Sorry it has taken so long to get this posted. These photos are a brief overview of sectioning the body. The quarters were not sectioned. The rockers were removed at the seam where they attach to the quarter panel. The inner rocker was replaced with a piece of 14ga to give some strength to it since it would no longer be a unibody . The cowl was sectioned around 1 3/8". I didn't worry about the firewall or original floor since it was all getting replaced. Sectioning the cowl and relocating the rockers was easy, the door frames were another story. I will be posting all of the construction photos on my website eventually, there are over 3 gig of photos.
      sectioning part2
      The door frames was the hardest part of sectioning the car. All the bracing and door structure had to be removed and reshaped after the door frame was fitted. There are a lot of complicated shapes in the front of the door frame and the door gets wider over a shorter distance with the section removed. This area couldn't be cut to fit like the cowl, it was cut as close as possible and many small pieces were fabricated to fill in the gaps. The door skin was initially cut and pieced back together. Once everything was sectioned and together the lower body line didn't look right so we made new door skins.
      Jan 2003
      Arizona
      .....I'm trying to get Jeff Isaacs to get on here with his yellow 69 Camaro that was in PHR a few months back..It holds several records at Maxton and he regularly drives it on the street around here. It's a budget build that is very fast and cool. Rabbit did the chassis and suspension.....
      Yeah get on that. We need more streetfighters around here. And that car's meaner and nastier than most.
      ________________
      Steve Chryssos
      May 2000
      Keith Turk from the ECTA Maxton N. C. came by Alan Johnson's shop to inspect the Cuda and advise us what needed to be done to get it to pass inspection for a 200 + MPH run. We are going to put in a supplemental bolt in main hoop for the cage, install a window net, add another fire system for under the hood, get a chute..we already made provisions to mount it..secure the front and rear windscreens, racing seat..few other misc and sundry items..Hoping to have it ready for the first meet that Hot Rod Magazine will cover..I think Hunkins is going to be there also. Poteet and Trepanier are trying to get their Bonneville Cuda ready to test there too. Rabbit says he's going to break 200 for the first time there with his 29 roadster.he has run 230 something @ Bonneville..holds records at both places with his backyard built hot rod. I'm trying to get Jeff Isaacs to get on here with his yellow 69 Camaro that was in PHR a few months back..It holds several records at Maxton and he regularly drives it on the street around here. It's a budget build that is very fast and cool. Rabbit did the chassis and suspension. Another buddy of ours has a 55 Ford F1 pick-up..2003 cobra blower motor..6 speed..whole rear cradle out of the mustang..pro-tour pick-up..Rabbit built it too.
      By what means do you plan to "secure the front and rear windscreens"?
      Nov 2004
      NW Arkansas
      bob can you get me any info on this pedal kit? I can see the master cylinder bowls are made but are those wilwood masters and slave cylinder?
      KENNY DAVIS HOTRODS
      The pedals and master cylinders are from Tilton . The master cylinders pivot on rod ends and have a balance bar for front to rear bias, nice setup but pricey http://www.tiltonracing.com/content.php?page=list2&id=3&m=b
      Nov 2004
      NW Arkansas
      Quote Originally Posted by htrdbuilder
      thanks Alan
      KENNY DAVIS HOTRODS
      Bada-Cuda
      Cuda Dreaming
      Cuda Shudda
      GF Cuda
      jp
      ​John Parsons
      Apr 2003
      phoenix az
      cuda
      i cuda....i did
