Results 1 to 1 of 1
02-19-2016 #1
1970-1977 Camaro Standard Steering column FS
1970-1977 Camaro or Firebird standard non-tilt steering column with the spline shaft. Will not fit 1978-1981 Cars unless you change the intermediate shaft and steering gear
Has a new ignition switch w/Key, horn cam and reproduction turn signal lever.
Came from a running working car, I would still be using it if I didn't put a tilt in my car. Turns fine and works, has never been rebuilt internally. Never been outside in the elements like most of the steering columns FS that came from old parts cars.
Splines on both end of the column are in good shape
Some scratches on the column, could use a fresh touch up of the paint, and a little dusty. See pics.
Still has a nice gasket on the firewall flange
Turn signal switch may not connect to a factory harness, I had an update harness in mine. So keep that in mind that you might have to swap the turn signal switch or get an adapter for the plug.
Turn signal lever will be removed and included for shipment
Will ship in a sturdy wooden crate and tracking provided. Shipping alone is going to be in the $25-30 range depending on your location.
$155 shipped to lower 48 states
My build thread
http://www.nastyz28.com/forum/showthread.php?t=241037
Paint Jail Experience
https://sites.google.com/site/paintjail/home
