    Results 41 to 60 of 85
    1. #41
      Nov 2016
      Lake Charles, LA
      Quote Originally Posted by Wldtang View Post
      What size rear tires and wheels? What back spacing and how much did you shorten the 8.8?
      I am debating between the aje rear setup or the martz
      295/35/18
      18x9.5
      5.25 b/s
      shortened 8.8 4 inches per side. 8.8 came out of sn95.
    2. #42
      Jun 2016
      Evansville IN
      Quote Originally Posted by 66Okasai View Post
      295/35/18
      18x9.5
      5.25 b/s
      Any pics of your rear suspension? Think a 315 / 35 /18 would clear the lower control arm?
    3. #43
      Nov 2016
      Lake Charles, LA
      I relocated the lower control arm to inside the frame rail. We added frame connectors and boxed in the end where the lower control arm mounts. We had to do this because of how we shortened the 8.8. If I remember right before we moved the arms, they were pretty close to the 295. It would be really close. I'll try to get some pics up later. Sorry to hijack the thread!
    4. #44
      Feb 2016
      No worry she hijack away. I'm still in process of workin on this thing and picsand imput are always welcome I'm going 325 on the back of mine The 315 I tryed fit pretty good and there's still room tho I did mess w my tubs a bit
    5. #45
      Feb 2016
      What size are u running in the front. I was hoping to get 18x 9s with a 255
    6. #46
      Jun 2016
      Evansville IN
      I was thinking of relocating the lowers to the inside if I went with the aje. I would like to see how you did this.
      Did you move the axles brackets inward as well?
    7. #47
      Sep 2011
Size:  106.3 KBWhich wheels are these?
    8. #48
      Nov 2016
      Lake Charles, LA
Size:  124.4 KBName:  mustang8.82.jpg
      The brackets were reinforced a bit more after these pics were taken. When we shortened the rear end, we pulled the tubes out, cut 4" off, and pressed them back in. So in short, the brackets are 4" closer to the chunk.
      The wheels are US MAGS Ramblers. 18x9.5
      Rusted rotors and wheels are the good ol' mocks.
    9. #49
      Jun 2016
      Evansville IN
      How did you get the tubes out?
    10. #50
      Nov 2016
      Lake Charles, LA
      Drilled the spot welds out. Then used a very large hydraulic press.
    11. #51
      Jun 2016
      Evansville IN
      Did you use the aje lower control arms? Do you know the length of them?
      Also what shocks and coil overs did you use?
    12. #52
      Nov 2016
      Lake Charles, LA
      Lower arms are 22 1/8 eye to eye. I made my own using stainless stock.
      qa1 coilovers are used. I don't remember the part number, but it was one of the shortest ones. Unless you use something like the Maier racing shock setup in the trunk, it'll be one of the longest for the height I wanted.
    13. #53
      Feb 2016
      [QUOTE=xsboost90;1209445]there is from what i remember a hole that lines up with the cross member. That one wasnt used but just for reference- the other four were drilled all the way through the frame- after you cut out all the other old stuff- and then open up one side of each hole- i did the bottom, slide a sleeve in there- supplied- and then weld it in. So my kmember has four large bolts that hold it in. The front suspension bolted up very nicely but they didnt have any info about a front swaybar and i had sold off my stock one. I bought a stock style bar biggest i could find and it fits, but i had to find some custom length links at autozone to get the bar to clear the rack correctly. I also opened up the existing notch in the bottom of the frame to clear the bar should i bottom the car out. I used a fox mustang cobra rack, 1994 spindles, 1997 cobra brakes 13", their struts and mounts. Oh i bought a Flaming river column that was "mustang length" and made my own mounts. Bought a (Ididit or Flaming river)-same stuff- shaft kit to connect the column to the stock rack and cut it to length. Worked very well and just had to ding my header in one spot to clear the shaft.
      Attachment 133910Attachment 133911Attachment 133912Attachment 133913Attachment 133914
      Can u do me a huge favor and measure from the front of the frame rail to the k member I think mine is sitting like an inch to far forward tire is real close to the fender in the from and a little gap in the back.
    14. #54
      Apr 2015
      Burlington KY
      damn your lucky im so nice! Ok looks like from the front edge of the k- member to back of the swaybar mount is 2" and from the front of the K-member to the end of the bottom of the frame rail is 19 1/8"
    15. #55
      Feb 2016
      K member
Size:  238.3 KBThanks for that. It's hard to tell w this small spare tire but the one rim I put on it still like an inch or too forward in the wheel well we followed those crappy instructions but obviously we need to re do it
    16. #56
      Sep 2011
      What size front wheels are you using?
    17. #57
      Feb 2016
      18x9
    18. #58
      Where did you get the AJE shock towers from? Custom made?
    19. #59
      Feb 2016
      Quote Originally Posted by sj9ers View Post
      I got them from AJE. I guess I have the "old suspension kit " and the tire fits to forward in the fender so we need to cut it and adjust it to move the wheel center to fit that size tire and rim
    20. #60
      Feb 2016
      Trans tunnel
Size:  254.1 KBName:  IMG_9884.jpg
Size:  185.3 KBLlittle bit of trans tunnel work to get the T56 under there
