    Results 1 to 10 of 10
      St.Petersburg, FL
      Red pinstripes for Rival S?
      Does anyone know who can put a red stripe on them...?
      Matt
      '69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 T56 Magnum and once again tuned by Ed!
      '69 Camaro Convertible, all DSE Stuff, LME 430 LS7, tuned by Ed Hutchings and built by http://www.gforcedesignconcepts.com/
      Beach Park IL
      Diamond back. www.dbtires.com
      They will only do it on new tires and they prefer that you buy the tires from them.
      Donny
      Dec 2010
      Fredericksburg, VA.
      There is a company I ran across online that sells tire lettering kits that are vulcanized on tire side walls using common tire patch technology and in addition to the lettering they sold a white side wall and a red line side wall. I can't seem to find them now but if I do I will post the link.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2010
      Fredericksburg, VA.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      St.Petersburg, FL
      Perfect...thanks Steve!
      Dec 2010
      Fredericksburg, VA.
      Here is their actual red line kit.
      https://www.tirestickers.com/redline-tire-kits/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Beach Park IL
      Nice! Hadn't seen that before.
      Donny
      Jan 2012
      Milford, MI
      The thing about that kit is that you'd need to find a strip that is (at minimum) the width of the red line all the way around the tire where there are zero markings/words. That's actually pretty rare on today's tires. The cool thing about Diamondbacks is they have smooth sidewalls after they modify them. It really cleans up the look and makes it appear less busy and cluttered.
      Jun 2010
      Deployed
      I suggest getting the stripe on the rim. If it's blacked out, it will look the same
      1970 Camaro/DSE build
      Feb 2003
      Houston, TX
      Those stickers look nothing like the quality that DB does. I had them do a set on my '70 Chevelle. They shave all the letters off of the sidewall, making it perfectly smooth. Then the rubber strip is actually molded into the sidewall like it was built like that. Not just a stuck-on decal.
      Costly, but great detail.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
