Thread: Mig welding thin to thick
11-02-2005 #1
- Feb 2005
- 320
Question???? When mig welding say 1/8" thick mild steel to say 1/16" mild steel you would still use the heat/wire speed setting for the thicker metal correct??? If so when welding the two do you start the bead on the thicker and just kinda roll it onto the thinner metal??? When welding ss to mild steel does it require a different approach than regular mild steel? And finally when welding ss 304 to ss 304 does this require different heat/speed ratings than normal mild steel. Example: My welder recommends using a certain wire speed and heat for 1/16" mild steel. Would the same settings apply welding 1/16" ss 304 but of course using different wire. Thanks Chris
