      Feb 2014
      Georgia
      Expansion Valve or Orifice Tube?
      I'm in the process of retro fitting a new condenser, dryer, compressor and A/C lines to the factory evaporator in my 70 Roadrunner. The factory system used an expansion valve attached to the evaporator line coming out of the firewall. I would like to replace the expansion valve assembly with just a 90* fitting and ez-clip hose.
      My question is can I use an orifice tube in place of the expansion valve assembly and where should the orifice tube be plumbed in the system?
      Steve - 1970 Roadrunner
      Oct 2015
      With an exp valve you have a drier in the liquid line(line between the condenser and evap).
      When an office tube is used you do not have a drier, instead there is an accumulator in the suction side of the system.
