Results 21 to 25 of 25
Thread: Hotchkis Leafs or 4 Link
01-08-2016 #21
The StreetGrip system would work very nicely for your application. A coilover/tubular control arm/4 link system would have more tunability for ride height and spring rates, but many times that aspect is lost on the casual driver. Here are the items in the StreetGrip package that I think would be most valuable in a competitive driving event:
1. dual rate coilsprings - the intial spring rate during the first 1" of suspension travel is quite tame to offer a great ride quality. When you hit a large bump or corner the car hard enough to compress the spring beyond that first inch, you transition into a much former spring rate that will resist body roll...and offer better handling.
2. tall upper ball joint - GM musclecars suffer from poor front suspension geometry...the loaded tire goes into positive camber on compression [tire leans away from the turn]. By installing a taller upper ball joint we change the camber geometry so the loaded tire leans INTO to turn...greatly improving the cornering power and overall feel of the car.
3. composite leafsprings - in addition to being 60-80 lbs lighter than traditional leafs, they offer a more appropriate spring rate for better road manners and handling.
4. delrin bushings - as far as I know, we are the only people to offer a delrin bushing system for the oem control arms. Delrin allows free rotational movement of the control arms and eliminates any unpredictable movement of the control arms during cornering. We also use Delrin in the leafspring busings for the same reasons.
5. larger swaybar with Delrin bushings - many companies offer larger swaybars to control body roll, but our use of Delrin bushings eliminates the sticktion that compromises ride quality and predictable handling.
6. adjustable shocks - our HQ Series rebound adjustable shocks can be tuned to optimum ride quality AND then turned up for optimum handling.
As far as ride height, we have images and fender height dimension published here : http://www.ridetech.com/info/streetgrip-dimensions/
We don't offer a rear swaybar for the leafspring applications because we have determined that it is not needed. The car is better balanced without a rear swaybar.
Bret Voelkel
Founder/ Former Owner
How do you spell Impossible?
