    Results 1 to 15 of 15
      Brake data logging yields surprising results
      I've recently added data logging to my Z06, including brake line pressure. I have two different brake kits for the car, neither of which are stock. I did a controlled experiment of slowing down from 60 mph and logged the brake line pressure and longitudinal G forces (how fast the car slows down).
      Here's brake kit 1:
      • psi Long-G
      • 985 -1.19
      • 1097 -1.26
      • 1200 -1.16
      • 1249 -1.16
      • 1057 -1.11
      Here's brake kit 2:
      • psi Long-G
      • 538 -1.11
      • 603 -1.21
      • 599 -1.11
      • 462 -1.09
      • 502 -1.02
      • 597 -1.07
      • 488 -0.88
      The difference is remarkable. Both kits achieve roughly the same amount of negative G forces, which largely shows the tire's mechanical grip. The slightly lower negative G numbers in the second set are probably just due to slightly damp roads I think. Kit 1 takes approximately twice the line pressure to achieve the same braking as kit 2.
      The car is exactly the same other than the brakes. I logged data for kit 1, then put the car on the rack and swapped the brakes, bled them, and logged the data for kit 2 the next evening.
      ​John Parsons
