    Thread: Mixing A arms?
      Jan 2014
      Portsmouth NH
      Mixing A arms?
      Ok I am not one to mix brands. However I am in a strange situation here.
      So I have been running a Global West upper (CTA-79A) for years and stock lowers with Del-A-Lum bushings. I was running a custom spindle (taller etc.) that someone made for me which failed this weekend (yeah that sucked!).
      So now I want to replace the spindle with the ridetech Tru Turn system and replace the lower A arm with a ridetech Strong Arm and go to coil overs. That would mean mixing the GW upper with the RT lower plus the other bits and bobs of the Tru Turn.
      Has anyone ever run this combo or has any experience with this combo before? Normally this is not something I would consider but if it would work fine it would save some money ($450).
      Cheers Steve
      Dec 2010
      Fredericksburg, VA.
      IMO, you would be better off selling your GW uppers here on the classifieds or craigslist and purchasing a complete ridetech system.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Apr 2012
      Woodstock, IL
      Mixing A arms?
      Usually mixing the lowers poses more of a problem because of shock mounts (affects shock length, clearance to shock bodies, etc).. I don't see a problem with running different uppers since the shocks don't attach to them. Since they're also both designed for a stock spindle, shouldn't have any issues there.
      If you need a quote on any ridetech components, were a dealer for them.
      SchwartzPerformance
      Jan 2014
      Portsmouth NH
      Thanks for the info. I was hoping that the uppers were not going to be an issue. I will try and call ridetech today and get their opinion also. I will e-mail you to get a quote. Cheers, Steve
      P.s.- email sent to [email protected]
      Aug 2012
      Peoria, AZ
      I have run DSE uppers with my ridetech lowers for several years with no issues. That doesn't mean that your setup will perform the same though.
      Do your GW upper arms position the upper ball joint in the stock location or is it moved back or in from stock? You need that answer first before deciding on a strategy.
      Lance
      Jan 2014
      Portsmouth NH
      Thanks for the quick turn around on the quote!
      Quote Originally Posted by Motobrewmaster View Post
