    Results 1 to 9 of 9
      Dec 2008
      Detroit
      Need help with tire sizes 18/19 combo
      I'm at the point right now where I need to start looking for tires. The current set I have on my wheels were just for mock up purposes. My wheels are 18x9 front and 19x10 rear. This car will be street/auto-x. Any feedback is greatly appreciated.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Dec 2008
      Detroit
      I'm considering Nitto NT05 275/35/18 front and 305/35/19 rear. Anyone know whats the most difference the width between front and rear can be before it will cause and issue?
      Chris--
      Apr 2012
      Woodstock, IL
      We run 335/275 on our tempest and it hauls around corners. Sure maybe it'd handle better with 315's but I see no issue with those sizes.
      -Dale
      SchwartzPerformance
      Dec 2008
      Detroit
      Quote Originally Posted by Schwartz Performance View Post
      -Dale
      Thanks for the response Dale. Trying to make the right decision when I'm spending that kind of money.
      Chris--
      Mar 2012
      Escondido CA
      If you want a good Autocross tire, avoid the Nitto NT05. Any of the other 200TW tires are better. If I had your wheels I would probably run a Bridgestone Re-71R 265 or 275 up front, 275 or 285 rear. The RE-71R will stick better than the other 200TW tires, but will also wear out faster. Hankook RS-3 is a longer wearing option, and a good mix between handling and street wear. Hankook also has a 305 available for the rear.
      1973 Corvette Factory Primer Car
      1969 Barracuda Convertible
      1967 Plymouth Valiant
      Dec 2008
      Detroit
      Quote Originally Posted by Tomswheels View Post
      I just looked at the RS-3, and did a little web searching. Seems like the overall feedback is good and its a great street/auto-x tire. I was looking at sizes also. I see the 305 is outside of the minimum rim width for this tire by .5". I did find a pic online of a one mounted on a 19x10 and noticed no sidewall bulge, which would lead me to be leave less flexible?. The next width size down is 275 which is a little narrower than I wanted to go out back.
      Chris--
      Dec 2010
      That 275 will work just fine in the rear, we have a friend that has run 275x19 and 305x19 on the rear in FS and it had great handling and traction with both. I have run 275x18 on a 10.5 in the rear and it was very good only marginally worse than a 335x18 Rival S on 12's. Bridgestone RE71R's are great tires!
      Mar 2012
      Escondido CA
      The 305 would be fine on a 10 inch rim, but realistically it won't handle any better than the 275. Of course I ran 335s (NT05s actually) once on a 10 inch wheel so a 305 would be easy...
      Dec 2008
      Detroit
      I ended up with S-04 Pole Positions.... 275/35 fr and 295/30 rr......
      Chris--
