      Melbourne, FL
      Wire size for gauges and dash lights??
      I'm getting ready to start wiring up my gauges. I was curious what is the proper size of wire to use. I'm thinking 14ga is about right. Not a lot of current involved. Dash lights will be all LEDs also.
      Thoughts ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jacksonville, FL
      I have used 18 gauge wire without any issue with gauges (like autometer and Dakota Digital). Never had any issues.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Melbourne, FL
      Thanks. And since gauges and the bulbs inside them don't draw a lot of current I assume it's ok to run separate power and lighting circuits in series.
      I'd use 22g. You're drawing less than 3A, over a distance less than a meter, and 5% voltage loss is not an issue. 24g is actually big enough, so go to 22g for some engineering margin.
      http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
      John Parsons
      Jacksonville, FL
      Yeah, I ran all of the Ign and ground wires in series except for the turn signal bulbs. One time when I ran the turn signal grounds in series with the others, I would get a "windshield wiper" indication in the other gauges when the turn signals were on. I just ran those grounds to another location.
      Chris
      Melbourne, FL
      Thanks guys!!!
