    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 78
    Thread: 80 Camaro Build
      Feb 2015
      Montana
      80 Camaro Build
      Finally getting around to starting my build thread. Three years ago, I bought my 1980 Z28 and promised my wife I would enjoy the car as is. Well...things change, thank goodness for an amazing wife. The car had rust in the floor and trunk, so Nov, 2014, I pulled the car in the shop for disassembly.
      Feb 2015
      Montana
      I decided to replace my 80 floor with a 70-73 floor. Was surprised to find that they do not make a full floor for the later 2nd gens. I was originally going to do everything myself, but decided for the sake of time, to have a restoration shop replace the floor and trunk. I really regret this, but oh well. Here is the before and after pics. Check out the beautiful fiberglass work from the previous owner. I still need to do some modifications and the roll cage before the seam seal and paint.Name:  image.jpg
Size:  164.1 KBName:  image.jpg
Size:  184.9 KBName:  image.jpg
Size:  170.3 KBName:  image.jpg
      Feb 2015
      Montana
      Next on the list was the suspension.
      After hours and hours and hours of internet research and reading this forum, I decided to go with Custom Works 2G suspension kit. Along with their subframe connectors, solid body bushings, and 2G bar. I also upgraded to front viking dual adjustable coilovers, and viking dual adjustable rear shocks. I really appreciated Keith in helping me pick out my suspension. So far, I have my rear leafs mocked up on my rear differential and I'm currently working on the front subframe. Hopefully, I'll finish welding in the upper coil over brackets and 2G bar this week. Then prep and get some primer and paint on the subframe. Here's some pics of my #1 Ace mechanic, rear leafs on the diff (only pic I have is in the background behind my new welder), and how the upper coil over brackets look (I don't claim to be a good welder). I was impressed by how well the coil over brackets fit, and how easy the mod is. Name:  image.jpg
Size:  210.5 KBName:  image.jpg
Size:  228.1 KBName:  image.jpg
Size:  134.6 KBName:  image.jpg
Size:  202.9 KBName:  image.jpg
      Feb 2015
      Montana
      For the rear differential, I decided to go with a Quick Performance fabricated ford 9", 3.89 ratio, Detroit trutrac, 31 spline QP axles, 1/2" arp studs, caltrac brackets and Kore3 C5 rear brakes. I'm really happy with how it turned out, can't wait to get it under the car. I'm equally curious/nervous on how the wheels are going to look, bought them new/used. I thought they would be good for mockup, but I ended up with smaller brakes because I got cheap. Oh well, at least I'll get it on the road a little faster. Name:  image.jpg
Size:  198.1 KBName:  image.jpg
Size:  173.2 KBName:  image.jpg
Size:  199.2 KBName:  image.jpg
      Feb 2015
      Montana
      Aeromotive fuel pump installed. This system installed really nice in the stock tank IMO.Name:  image.jpg
      Aug 2006
      S.W. Florida
      Looking good so far
      68 Camaro TT LSX 427 "Golem" / click the link
      https://www.pro-touring.com/threads/...ighlight=golem
      sponsored by
      www.FactoryFinishPDR.com
      Feb 2015
      Montana
      Thanks, I really appreciate that I can post my simple build amongst all the amazing projects on this forum.
      Jun 2013
      San Diego
      Looks good.
      What's the plan?
      Brian
      1972 C10 - 454/TH400 - Short bed conversion - https://www.pro-touring.com/threads/...1972-C10-SoCal
      1970 Nova - LS Swap - https://www.pro-touring.com/threads/...Cal?highlight=
      Sep 2015
      Looks good!! Glad to see the QP 9" I also just ordered one for my Mustang, just waiting for it to arrive. Hows the quality look?
      1966 Mustang Coupe
      5.0 EFI- T5
      Feb 2015
      Montana
      Quote Originally Posted by bs46488 View Post
      Looks good.
      What's the plan?
      Short Term(12 months)
      Finish suspension, brakes, paint/undercoating on everything except exterior(sleeper), 6 point roll cage, finish fuel system, run old 350/350 combo, old interior
      Long Term
      Stroked LS2
      T56 magnum
      Interior
      Extended Long Term
      Exterior body, never stop making it better
      Had to check out your projects, and found one of your quotes that started "yes you can". This is exactly why I regret not doing my own floor and trunk replacement. Wouldn't of been perfect, but much more gratifying. My roll cage is the last thing I will hire out, safety is my first concern. Your 72 is a great project.
      Feb 2015
      Montana
      Quote Originally Posted by rhurley View Post
      Appreciate it.
      I'm very happy with the quality, keeping in mind their price points. I feel like I received a lot of value for the money. I would definitely purchase another. I'll be really curious to hear how you like yours, not a lot of reviews out there.
      Feb 2015
      Montana
      I was able to finish all my mods on the front subframe this weekend. Finished welding in the coil over brackets, I'm running steel bushings on the stock lower control arms. The aluminum coil overs are going to really pop against the satin black paint.
Size:  149.9 KBName:  image.jpg
      Welded the 2G bar on the front, I didn't get crazy with the welding on this one in case I need to remove it at a later date.
Size:  199.3 KBName:  image.jpg
Size:  199.0 KBName:  image.jpg
      Since I have a 80 subframe with a 70-73 floor I had to move the the rear body mount farther back. I boxed in the frame where the old mount was accessed. Was going to try and add some more structure to the rear of the subframe, but decided that welding the subframe connectors to the frame would be sufficient. Do you guys for see any problems with this?
Size:  188.7 KBName:  image.jpg
      Feb 2015
      Montana
      Found some time to modify the front spindles for the Kore3 C6 brakes. I'm so impressed with the quality of Kore3 products, would highly recommend.
Size:  182.5 KBName:  image.jpg
Size:  200.3 KBName:  image.jpg
      Here's a pic comparing the stock hub/rotor with the C5/C6 325mm rotors.
      Nice progress. I agree about KORE3 products and Tobin is great sorce of information.
      Feb 2015
      Montana
      Well, hunting season is over, time to get back at it. I decided to have the subframe blasted and powder coated. I think I'm going to do more powder coating wherever I can, which was not the original plan. I also picked up some lizard skin, 2 gal SC, 2 gal CL, and the applicator gun.
      I am using spc uca's with tall ball joint and stock lowers, steel on steel lca bushings. Viking double adjustable coil overs, and hellwig sway bar. Now I need to get new grade 8 hardware and tighten everything down.
Size:  221.0 KBName:  image.jpg
      Apr 2010
      Very cool build. I lover the 80-81 Z-28s. Would you mind PMing me with the cost of powdercoating the subframe? I need to have mine SB and PC'd too.
      JIm
      Feb 2015
      Montana
      Thanks Jim, pm sent.
      Chicago
      Great update and I am really liking the front suspension set up.
      marty-mj
      Florida
      Coming along nicely!
      I used a 81 subframe in a 70 body so I've been through moving the body mount holes in a late style frame. Using a late frame with the early rear body mount position you'll notice the way the frame metal is overlapped and welded inside the frame where the new mount hole is will cause a solid body mount to be tipped inside the frame. You may want to make a spacer shaped to fit so the body mount bushing sits flat inside the frame. Depending on the frame connectors you have you'll probably also need to trim the indentation at the rear of the frame rail on one side to slide the early style frame connector into the rail. Hopefully you have frame connectors made for the early style body mount.
      In the pic below you can see the spacer I put in mine and how the rail's been trimmed to slide in the connector. I fully boxed mine afterward and trimmed the bushing between the body and frame to compensate but that might be overkill. Details of all the frame mods (done so far)are in my build thread.
      Feb 2015
      Montana
      Thank you! Nothing fancy...but I like it.
