    Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 155
    1. #21
      Dec 2010
      Apex, NC
      Quote Originally Posted by c91x View Post
      Quote Originally Posted by Crestronwizard View Post
      It's the 4R70W. Bolts up no problem. There isn't a controller out (yet) for the 6 speed auto. Only a couple of people have made the 6 speed work and I'm not interested in adding the time and complexity to make it work.
      HP Tuners can now disable PATS... so you could use the stock ECU to control the 6r80
      Finally!Thats good to know.
    2. #22
      Sep 2015
      SW KS
      Hmm... I never thought about doing something like to my current truck. I've got a pretty minty 82k mile 90 F-150 that I rebuilt the 351 in. I'll be watching closely!
    3. #23
      Dec 2010
      Apex, NC
      Apr 2014
      Great looking truck to start with! Good luck with the build!
      Pat
    5. #25
      Nov 2011
      Long lonesome highway E. of Omaha (SW Iowa)
      I like it! Ive been daydreaming for some time now about a 79 super cab 2wd with a 5.0/6r80 swap. Seems like a low mile truck take-out engine and trans with harness and everything goes for around $6k or so on ebay, which isnt bad for a pretty complete setup. Unfortunately I have way too much going on to do it, so Ill enjoy living vicariously thru you. =D
    6. #26
      Dec 2010
      Apex, NC
      Quote Originally Posted by Decurion View Post
      Thanks . This one has been interesting so far. The Independent Rear stuff arrived today so that's next. I have to figure out the brakes and which A/C unit to run.
    7. #27
      Dec 2010
      Apex, NC
      Test fitting the engine and trans
    8. #28
      Oct 2011
      Maryland
      Who one step closer! So it fit like a glove? with the truck engine mount? versus the coyote engine mount one.
    9. #29
      Dec 2010
      Apex, NC
      1972 F-100 Project 4 Kids 4 Projects
      The truck mounts ended up not working. Used 4.6 mounts. Modifying a 4.6 oil pan to fit. I'll post pics of that once completed.
    10. #30
      SF Bay Area
      Neat project.
      Which year Crown Vic front ends fit - I think it might be something like '05 and up, right?
      Is that kit you used to tie it onto the trucks frame rails or something you came up with?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    11. #31
      Dec 2010
      Apex, NC
      Quote Originally Posted by chunger View Post
      Neat project.
      This is out of a 06. Used the adapters from http://team321.com/truckirs/truckirs.html
    12. #32
      Minneapolis, MN
      What did you end up doing for the rear lower control arm mount point? The kit doesn't show if it includes anything.
    13. #33
      Dec 2010
      Apex, NC
      Quote Originally Posted by brawls43 View Post
      It comes with a plate that matches up with the plate on the end of the rear lower control arm. Those two pieces bolt together. Then it gets welded. We still had to box it in ourselves as it does not fit flush with the frame.
    14. #34
      Dec 2010
      Apex, NC
      The factory 5.0 pan doesn't fit so we got a 4.6 pan and added the necessary bolt holes in the front. Other than those missing, the pan is a perfect fit.
    15. #35
      Dec 2010
      Apex, NC
      More Teardown. Starting on the I.R.S. next.
    16. #36
      SF Bay Area
      Are you using the same vendors kit for the IRS that you did for the front?
      How are the instructions?
      chunger
      '68 Ranchero 500
    17. #37
      Dec 2010
      Apex, NC
      Yes. I'll let you know around Tuesday
    18. #38
      Feb 2013
      Berwick, South Louisiana.
      The engine looks pretty low in this picture. Would it have caused any problems to have mounted it higher to better clear the frame rails? It's looks like it will be tight to change the alternator and fit the exhaust.
    19. #39
      Dec 2010
      Apex, NC
      Good clearance for the alternator and the exhaust is good now, had to make a little room on the passenger side for the exhaust but that was only because we had boxed the frame. Funny thing is, after doing the mustang I haven't even thought anything was tight on this .
    20. #40
      Feb 2013
      Lol I hear that. That engine bay is huge. You should have plenty of room in there.
    Tags for this Thread
