      Jun 2014
      rear suspension help needed
      Looking to decrease body roll greatly in my 85 c10. Currently the truck is lowered with a rear flip kit and cut coils roughly a 4/6 drop. Since my budget is very tight I'm trying to optimize what I have rather than spend more on components than the entire truck is worth currently. I plan to do this build in stages, with a end goal of a fun spirited daily driver, that's a beast on winding back roads.
      Currently I have changed the ball joints and have a urethane control arm bushing kit to install. I also have a factory front sway bar with urethane bushings for the front as well to create a decent stock front end. Out back is where I'm struggling to develop a plan of attack. To stay in my budget I want to keep the rear leafs so I upgraded to poly bushings when I did the flip kit and that's where Im at now. Would it be better for me to find a stock rear sway to retrofit (any suggestions are appreciated ) or increase the spring rate with the addition of helper spring shocks. I'm leaning towards the helper spring shocks since I need to upgrade the shocks anyway and the fact that they will stiffen my rear up. Please help thanks
      Sep 2012
      San Diego
      i would go with the rear sway bar. i cant remember ever seeing a chevy truck with rear sway bar and i build differentials for a living so ive seen a lot of rear suspensions. i believe suburbans have a rear sway bar. they have pads welded on the housing so it will take some creativity to put on the truck housing. i bet a sway bar off of a ford or dodge would be easy to make work on the chevy. need to spend some time in the salvage yard looking to see what you can find.
      71 maverick.
      71 comet in build process.
      i work at Current Auto Performance www.currentautoperformance.com. i also build the differentials for San Diego Gear and Axle.
      Jun 2014
      Ok thanks I know a lot of guys were using explorer rear sway bars on s10's when I had my blazer. So I'm thinking a expedition sway bar may work on a full size truck. Is there anything I can do to increase the spring rate on a leaf spring rear?
