    Page 6 of 27 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 16 ... LastLast
    Results 101 to 120 of 533
    1. #101
      Aug 2015
      charlotte
      Quote Originally Posted by DT69Cam View Post
      Awesome build. How was the fit with the stinger hood ?? Gaps, quality etc. ? Thanks!
      Gaps were pretty good.
      but it's takes a bit of modifying, at least to get it how I like it, It will still function in the same way as a cowl hood however it has the appearance of ram air.
      the press of the actually scoop part is quite curved, not as sharp as a corvettes original hood, and took a day and half of fab to get it to where it is now.
      Also after removing a section underneath it was revealed it was even primered inside which is something I'm glad i found out before paint.
    2. #102
      Jul 2016
      Quote Originally Posted by slimjim View Post
      Thank you!!
    3. #103
      Aug 2015
      charlotte
      More Progress!
      Excuse my watermarked and low quality pictures as they're taken from Instagram but November brought some great progress to the car.
      We decided to scrap the original plans with the firewall and start fresh with the laser cut firewalls Ambition Road make, the results are great and the install is a simple enough process. This will allow the wildwood master cylinder to bolt right in, hidden wiper motors inside the front fender, and although these are made to work with Clayton machine pedals, we'll be trying to make it work with the 5th gen pedals.
      After that Aaron begun reinstalling the front end sheet metal to gap the car perfectly, along with losing the keyholes. With some more minor touches on the front end we should finally be able to get started on the headache that is fitting the 5th gen interior...A year after schedule..
    4. #104
      It looks good, I wish I put the wiper motor under the fender. It is so much cleaner .
    5. #105
      Aug 2015
      charlotte
      gaps complete! just some finishing touches on the exterior and then the engine bay and interior work can begin.
      Also, I decided to copy the C10 that Ambition road built for Angelo Vespi and Aaron designed some gas strut style hood hinges, I like the simplicity of this and that I don't need to purchase another 'off the shelf' hood hinge like so many other, The hood sits a little low currently so we'll be installing larger struts to make things a little more functional.
      5th gen strikers and latches also working perfectly now.
    6. #106
      Jul 2016
      Awesome work.
    7. #107
      May 2011
      Brisbane, Australia
      Country Flag: Australia
      Yep, looking really good.
      1966 Plymouth Fury III
    8. #108
      Apr 2007
      Utah
      Looking good. Love the hood hinge and door latch
      Sam
      Northern UT.
      '68 Camaro "Bodacious"
      '56 210 2dr "Buckshot"
    9. #109
      Oct 2013
      Northern Virginia
      Looking good Jim! As your guy where he got those gap gauges...I want some!
    10. #110
      Aug 2015
      charlotte
      Quote Originally Posted by Cryptonomad View Post
      Hey John,
      they're actually 3/16" tile spacers from Lowes
    11. #111
      May 2013
      Colton Ca.
      Looks like the same ones you would use to lay tile?
      Oops they answered above.
      Ahmad B.
    12. #112
      Jul 2013
      St. George, UT
      Nice!
    13. #113
      Aug 2015
      charlotte
      A bit of progress on the radiator support and close out panel, incorporating VW hood latches of course.
    14. #114
      That close out looks great ! Nice job.
    15. #115
      Aug 2015
      charlotte
      Thanks, here's another picture from AR's Instagram.
      Picture lost, blame photobucket
    16. #116
      Nov 2007
      Windsor, Ontario
      Do you have the part numbers (years) for the VW hood latch assembly. I'm assuming that the will work on a 69 also?
    17. #117
      Jun 2006
      TX
      They need to sell those things! I'm in for one.
      Kyle
    18. #118
      Aug 2015
      charlotte
      Quote Originally Posted by HotRod68Camaro View Post
      I'll suggest it, the work is impeccable, I couldn't be happier with the progress made.
      Quote Originally Posted by AB69Z View Post
      No part number, however I purchased it on eBay by searching 92 vw hood latch, I just checked and they're plentiful, but theres a couple slightly different designs, one is a little stronger than the other, I bought these a year ago so I am happy to finally see them installed.
    19. #119
      Jul 2013
      St. George, UT
      Looking great! I like the shape of the close out, very cool.
    20. #120
      Nov 2014
      Byron, Ga
      WOW!!! awesome build
      '66 Chevelle BBC/TKO600r, Holley Sniper EFI, Tanks Inc, RideTech Air Ride, Wilwood, Billet Specialties Toploaders 19"/20", Nitto NT555G2, Octane Lighting LED, DIGI-TAILS Front & Rear, Randy's Spoiler
