    Page 15 of 27 FirstFirst ... 5 10 11 12 13 14 15 16 17 18 19 20 25 ... LastLast
    Results 281 to 300 of 533
    1. #281
      Sometimes it just works out that way. Good deal with the pedals. Make sure that you install some sort of positive clutch petal stop though so you don't overthrow the clutch master cylinder.
    2. #282
      Aug 2015
      charlotte
      It doesn't happen near enough!
    3. #283
      Aug 2015
      charlotte
      Another big couple of days in the garage, the first of which was spent protecting everything I didn't want to receive overspray followed by scuffing every inch of the car to receive feather fill G2 high build primer.
      then an even longer day taping up. This was to be expected since I want as little overspray on the interior as possible.
      Then finally I hit it with primer. I used a 2.2mm tip and reduced it 5-10% but even then it was hard to spray. Regardless, I got the whole Gallon onto the body, and am happy enough with the result.
      So today I had the less than fun job of reverting the garage back to its original state and then hit the car with some guide coat.
      I'll most likely give the car a few more days to really harden up then get stuck into it. I'm more than happy with the current gaps on the car and can't see a huge amount of filler work left in the future.
    4. #284
      Maryville, TN
      Ah yes, the "tiger stripe" days... remember them well. You're getting there man!
      Quote Originally Posted by slimjim View Post
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
    5. #285
      Aug 2015
      charlotte
      Still here... still sanding
      so far I'm very happy with it, not 'too many' areas needing further attention
    6. #286
      It looks good keep picking away at it!
    7. #287
      Vancouver, BC
      I am very happy with this!
      Is the purpose of the black valvecover-mounted bent plates just to conceal the coil plug wiring? Or any other specific reason? Just curious. Looks so clean!!
      1972 Nova, forged LQ4 with twin 6466's, T56 Magnum, OEM subframe w/ Speedtech front, Chassisworks gLink rear, Ridetech coils & Wilwoods, with a rear floater in the works --> http://www.ls1tech.com/forums/conver...1972-nova.html
    8. #288
      Aug 2015
      charlotte
      Quote Originally Posted by frojoe View Post
      That is the proform coil bracket, if you look at a picture below once the engine is further assembled, the coils now sit perfectly horizontal rather than angled. For now I will run it like that, but in the future I may consider hiding the coils on the subframe.
      - - - Updated - - -
      see here
    9. #289
      Aug 2015
      charlotte
      I have been doing bodywork for the most part of the last week, a crazy amount actually. progress is slow, but I'm very happy with it. I'll save the pictures until this stage of refining is complete, but my guess is I'll have another coat of high-build on it by this time next week.
      Meanwhile, most days I start by doing something else on the car, just so my life doesn't entirely consist of being dusty.
      I managed to get my clutch pedal connected, it seems 5/16-24 is a hard size to get an extension for the clevis, however it's done now.
      I ordered some billet window switches from ringbrothers a few months ago, then I forgot about them, but they finally arrived a week ago, and some point in the last few months I also ordered a 'gauge-less console trim' for the 5th gen console and decided to put my idea to the test. I'm very happy with the final result and the switches are a piece of art.
    10. #290
      What a sweet idea.
    11. #291
      Aug 2015
      charlotte
      Ok I have spent numerous days(every day since my last post) on the bodywork and finally the weather window started today so I didn't waste any time.
      I setup my redneck garage/driveway paint booth and hit it again with featherfill poly. I took zero pictures during the sanding process and none bar this one picture today.
      But I spent a lot of time refining the gaps over the last week, hit all the burn-throughs with epoxy and today it was ready.
      Tomorrow I plan to push it out, clean everything up, and take some proper photos for you all. first results are very satisfying!
    12. #292
      Aug 2015
      charlotte
      I had some trouble on the first round of poly so I bought a new gun with a 2.5mm tip and it sprayed remarkably better.
      very happy with gaps now.
      The rear spoiler might be my next big project as I've decided I'm nowhere near satisfied with it's fitment.
      iPhone pictures for now.
      That's about the extent of my sanding and bodywork for now though.
    13. #293
      Nice work it looks great, nice crisp lines. The body looks good all one color.
    14. #294
      Wow, that is a great job! Body work really is satisfying. All the cussing you do while you are sanding, but when you step back after it's done to look at the finished product makes it all worth it. Dude, you just need to paint it yourself! You already have the booth set-up, just buy the paint and let it rip. If you were laying down nice consistent coats with the primer, the paint really isn't much different. The clear was definitely more tricky as it tends to run easier, but I just did light coats and took my time. YOU CAN DO IT!!
    15. #295
      Great attention to detail in this build. Looks great.
    16. #296
      Aug 2015
      charlotte
      Thanks guys.
      Ryan, It has crossed my mind, I doubt my abilities but then again, I doubted doing this stage of bodywork also. I was kind of driven to do this part as the previous body shop made no progress, moved my car to the next state over and since I brought the car home, and I was home, I got studying and tackled it myself and I'm now very happy that I did. Plus the car made significant progress when the other option was a wasted 6 months.
      I would really like to continue sanding this second coat of poly, I'd hit it with 220 and continue hunting for any remaining lows...BUT.. this time next week I move back to Australia for the year...
    17. #297
      Aug 2015
      charlotte
      So another project on my mind for a while got some attention today. Ages ago I bought the 4.5" Truck-lite driving lights which are made to match the 27270C headlights. But I couldn't figure out how to mount them and to buy a set of the fester billet mounts and re-work them would be an expensive experiment.
      Well since these driving lights are most common for Harleys, I decided to get some cheap Harley pods and trim pieces from Ebay. So for about $18 I have these trim pieces that are sort of close to the 69 valance curve. They're far from perfect but I think with some nice tabs welded on the inside I should be able to get them to mount up pretty nice.
      This is before I cut out the original mounting bracket
      And after.
      I also found what could be a very nice PCM location. This would sit directly behind my double din display, should get great ventilation and "shouldn't" intrude with the vintage air I am yet to purchase, and best of all, it is directly above the grommet where the harness goes through the trans tunnel.
      I chose to use the dirty dingo E38 PCM bracket
    18. #298
      Nice job fitting them in.
    19. #299
      Oct 2011
      Great job! Can you post s link to the Harley pods?
    20. #300
      Aug 2015
      charlotte
      The pods I haven't fitted just yet, but these are the trim rings I used.
      https://www.ebay.com/itm/4-5-Light-V...item2cdb765dc7
      And these are the pods
      https://www.ebay.com/itm/4-5-LED-Fog...item3d71d3a5f7
