    Results 1 to 2 of 2
      Appleton WI
      Digi-Tails issue
      Painless harness.
      I installed the digi-tails rear LED conversion last night and I thought that when I put the car away last night everything worked as it should. I started the conversion of the rest of the car this morning in preparation for a car show Friday morning and I don't have brake lights or turn signals when the headlights are on.
      The four-way flashers light up like they should. When I turn the turn signals on, they are brighter on the side I have indicated but all of the lights come on and flash. When I hit the brakes, the front turn signals come on also. With the headlights on, the brake lights don't work and the four-ways don't flash. The turn signals also don't flash. This happens whether I'm using the no-load flashers or standard flashers. I tried using jumper wires to change which flasher connector got 12 volts and it made no change.
      I have a car show in less than six hours and I don't know where to look next to solve this.
      Thanks,
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
