    Results 1 to 19 of 19
      Nov 2010
      Dynamat question
      I've been looking at the dynamat extreme for my 68 firebird but it's pretty pricey. Does anyone have any other suggestions or is dynamat the way to go? Also how much will I need for the entire car (roof, trunk, floors, doors, firewall)? Thanks for the help!
      I've used Dynamat, Dynamat lite and RamMat. I actually liked the Dynamat lite the best
      Sep 2013
      this stuff is the best performing product at it's pricepoint. also it's nearly as good as the top rated deadener... to the point where the difference would be almost negligible. especially in our situation
      http://www.knukonceptz.com/mobile-au...ossus-edition/
      dont forget to top it with a closed cell foam:
      http://www.raamaudio.com/ensolite-iu...on-the-market/
      also, you can save money by following the 20% rule
      Scott
      '66 Chevelle
      Nov 2010
      The 20% rule? Also how many sqft do I need for my car? Thanks for the help!
      Apr 2012
      Woodstock, IL
      Dynamat question
      Were a dealer for Hushmat, they're well priced and same kind of quality as Dynamat. There are also vehicle specific kits that provide oversize cuts for each area of the car, and price per square foot isn't really any more.
      Hushmat is the only stuff that has OE certifications too.
      -Dale
      SchwartzPerformance
      Sep 2013
      Read this article. I'll try to find an independent test for most of the deadeners out there. The two higher rated products were from knuconceptz and sound deadener showdown
      http://sounddeadenershowdown.com/products/cld-tiles%E2%84%A2
      Scott
      '66 Chevelle
      Sep 2013
      Apr 2012
      Woodstock, IL
      Quote Originally Posted by scott_fx View Post
      Wow!
      Says they won't ship to any stores near me and will not ship direct. :(
      SchwartzPerformance
      Apr 2010
      Pittsburgh, PA
      Dynomat is kn the pricy side and when compared to 40 plus other competitor brands they perform about middle of the pack from what i remember
      I can post link to CLD test thread and post top performing 3 brands..which was SDS, Murdermat and knulonceptz kollosis in that order
      i should also have a spread sheet of some of the results with pricing
      72 buick skylark
      Apr 2010
      Pittsburgh, PA
      72 buick skylark
      Nov 2010
      Will the Dynamat extreme keep the heat out if applied to the roof or do you need to add the padding ect to it?
      Nov 2010
      Has anyone used the carinsulation.com, peel and seal or fat mat that was listed on the link above? If so how were your results?
      Apr 2010
      Pittsburgh, PA
      Also real question shiild be what are you trying to acomplish
      CLD matting like being discussed is to stop panel resonance (structual vibration) it wont help with heat nor air bourne noise
      these will need entirely different products
      ie thermal matting, Closed Cell Foam(Decoupler) and Mass Loaded Vinyl(air bourne)
      72 buick skylark
      Apr 2010
      Pittsburgh, PA
      Quote Originally Posted by firebirdzig View Post
      all junk in regards to sound damping
      results start on page 9 i believe. .not my results but chris from CA has done all the testing
      various forum members like me either sent samples for testing or contacted companies to send a sample to him for testing.
      Peel n seel and fat mat (rebranded peel n seel) are the worst performing products
      it does dampen but out of the main frequency of what you need ..plus its asphalt based..can smell in summer
      .will dry out over time and work less effectivly then it already does
      Car insulation isnt even a sound nor vibration dampner( no constraining layer )
      from grape vine its rebranded ez cool by low e
      Ive argued with the guy selling it..he doesnt want to hear it..as hes just a window tinter looking to offer an upsale..
      Car insulation should just be advertised as a thermal insulation as thats the only thing itll ne good for
      72 buick skylark
      Apr 2010
      Pittsburgh, PA
      No it wont
      Dynamat is a CLD which is to absorb panel resonance/ding sounds like from rain drops
      It absorbs that in return create heat
      my bro did 100% coverage of dynomat extreme on his mav floor pans and i cant even lay my left foot on pan on passenger side or my foot feels like its on fire
      Sound insulation companies like to make claims that their product does everything... structural sound, air Bourne sound and heat control...when in fact they only do 1 and fail miserably at the rest
      you can do 25 % coverage of the CLD for the headliner then do a layer of heat matting like heatwave pro or perhaps carinsulation or lava shield
      72 buick skylark
      Nov 2010
      So what would be the ideal set up for sound and thermal protection? I (probably like everybody else) want thermal and sound protection.
      Apr 2012
      Woodstock, IL
      Dynamat question
      We usually do Dynamat or Hushmat then cover with Dynaliner or Silencer Megabond by Hushmat. For the most protection, BoomMat makes UnderCarpetLite to help the heat even more.
      Also helps to do what you can to the exhaust, like coat it, heat shield around it, etc. just think about what OE does.
      -Dale
      SchwartzPerformance
      Apr 2010
      Pittsburgh, PA
      Just about any butyl based CLD is good skip the butemin/asphalt type
      thats your first layer
      Secondskin audios heatwave pro..or some other brand thermal matting like car insulation, or lavashield (not sure how these compare to each other..tempted to buy and test)
      Then top layer you can do second skin audios luxery liner pro which has closed cell foam melted (not glued) to mass loaded vinyl.
      or you can do seperated layer of CCF then MLV
      Depends on how well you want a quiet ride
      72 buick skylark
      Sep 2001
      Accord, NY
      It seems like the roof is limited in how thick you can build up. With a layer of dynamat , there is only so much room left in the middle where the cross bars snap in for the headliner material. I currently have only the dynamat installed in the roof of my Bel Air. Even on a cloudy day the interior is very warm to the touch. Next up will be some type of thermal product.
      68 camaro - SOLD
