    Results 1 to 9 of 9
      milledgeville ga
      Rear Wheel Clarence
      How much clearance is need between frame rails and outer rear quarter? Wheel are 18 by 12 inch wheels.
      milledgeville ga
      Trying to measure for rearend
      Depends on the car - shape of wheel openings and also ride height. No easy answer that I am aware of.
      Dec 2008
      Detroit
      As Don said there is now easy answer to this question. It might help if people knew what type of car?
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Apr 2012
      Woodstock, IL
      Rear Wheel Clarence
      12 inch wheels are actually 13" wide.. 335 tires are just a tiny bit wider overall, so figure a minimum of 14", but preferably more to allow for suspension movement and tire sidewall flex.
      But yes it does depend on the car.. A lot of quarter panels are deceiving, and ride height is a factor.
      -Dale
      SchwartzPerformance
      Car? Year? Tires? Lowered?
      milledgeville ga
      1969 camaro 18 wheels with 335 tires ridetech coil over suspension.
      Nov 2009
      Austin Texas
      Do you already have the wheels? I have about an inch of clearance to the inner and 1/2 an inch to the outer. As the rear axle articulates it pulls the tire towards the inner and away from the outer so keep that in mind.
      Sep 2008
      Sacramento, CA
      With that tire, that car, and a stock/modified stock frame rail you don't really have an option for clearance. You just have to center it in the wheelhouse as best you can.
      If you are cutting out the floor and backhalfing the car with new frame rails, then you have a lot more options. We typically recommend two inches on either side. The taller the sidewall the more it will deflect under cornering and move toward the inside of the corner.
      My best recommendation is to measure the car and the wheel/tire combo that you're going to use. EVERY car is slightly different. We have a worksheet that has a lot of math that double checks itself.http://www.cachassisworks.com/cac_worksheets.html
      Carl Ogren - Sales and Tech
      Email us to get your Chassisworks/TCP Equipped vehicle featured on Facebook!
      Chris Alston's Chassisworks - Phone: 888.388.0297 ext 247
      Chassisworks - TCP - Varishock - Component Drive Systems - KP Components
