      Nov 2013
      near Charlotte, NC
      Options for Rear Disk Brakes (with e-brake) for 2nd Gen Camaro?
      I have a 74 Z28 Camaro and installed the rear disk brakes that came on the later 2nd gen Firebirds several years ago. Only problem so far is the e-brake cable rubbing on inside of the tire on drivers side. Does anyone (Wilwood, Baer, etc) make a rear disk brake where cable doesn't run parallel to driveshaft? I want to run wider rear wheels that will make the problem even worse.
      Conrad
      Original owner '84 Grand National. CAS V1 (big) front-mount intercooler, Comp roller hyd cam, Champion Al intake/heads, T66 turbo, 3.5" custom cat-back exhaust, RideTech TruTurn front & DSE rear swaybars/ctrl arms, Ridetech 3-way coilovers, Baer 6P 14/13. FAST w/TouchScreen & GM Flex Fuel sensor, 120 lb injectors, Ricks SS tank, Aeromotive Eliminator pump.
      Nov 2013
      near Charlotte, NC
      I am amazed that there have been zero replays! Anyone?
      Conrad
      Oct 2010
      Sacramento, CA
      4th gen camaro brakes (ls1) are rear pull and may work.
      Rick - 1969 Camaro - LS1 driven daily
      Southern Indiana
      S10 rear disc makes good swap. the complete p brake/adapter/backing plates run around $150 a side, bolt it on slide on a rotor and caliper and your done.
      Here is link to my post on S10 parts:
      https://www.pro-touring.com/threads/...10+disc+brakes
      Lots of ways to go, the staggered shock Fbody guys like using two of same side calipers and brackets I believe.
      I have two 4wd backing plate setups,with trashed shoes. take offs from customer car, it needed other work so after pricing parts and labor sold complete GM setup backing plate and all,,,both sides.
      Lee Abel
      AFTERMARKET PERFORMANCE
