      Southern California / Maryland
      6.1L Hemi Stand Alone Wiring Information
      Because so many people ask.... I'm giving a cliffnotes version of what needs to be done to make your harness applicable to an older muscle car... . this will work for a 5.7L or a 6.1L Hemi - I'm 99% sure a 6.4L as well.... no first hand experience though....
      Cliffnotes.... You'll only be using the Black, Orange, and White connectors for this one.... if you're using the mopar trans then you'll use the green connector and be asking for a lot of ass pain going with it.
      BLACK CONNECTOR:
      Pin 29: Wire to terminal 86 / 30 on Auto Shut Down Relay (ASD)
      Pin 30: Wire to pin 85 on a Starter relay
      ORANGE CONNECTOR:
      Pin 8: NOT USED
      Pin 22: NOT USED
      WHITE CONNECTOR:
      Pin 3: ASD Relay terminal 85
      Pin 8: NOT USED
      Pin 11: A/C Relay terminal 85
      Pin 14: NOT USED
      Pin 19: ASD Relay terminal 87
      Pin 20: NOT USED
      Pin 23: NOT USED
      Pin 28: ASD Relay terminal 87
      Pin 29: NOT USED
      Pin 35: NOT USED
      Pin 37: fuel pump relay terminal 86
      Pin 38: Starter Relay terminal 86
      This should be getting 99% of you guys on the road.... If you are using the NAG1 or truck trans - just use the green connector and plus into the trans.... any other specific questions PM me and I'll do my best to answer while I'm in the Middle East.
      1966 Chevrolet Chevelle 300 Deluxe 350 / 350 auto
      1968 Dodge Charger SRT8 6.1L Hemi / 6-speed
      1964 Dodge Polara 8-71 Blown 440 / 4-speed
      1998 Toyota 4Runner SR5 3.4L / 5-speed
      2013 Dodge Challenger R/T 5.7L Hemi / 6-speed
      Oct 2014
      Country Flag: England
      Hello is the ASD relay fused?
      If so which terminal?
      Thanks in advance
