Thread: Help pick stall speed.
10-20-2005 #1
- Mar 2005
- 467
First, got a 383, approx. 425-450 hp, same tq, race built 700r4, 3.73 posi. Burned up the first converter, got new converter but stall too high, approx. 3100-3200. Allowed one converter stall change. This converter warrantied to 1100hp. Can't get tires loose when shiftiing form 1st to 2nd and even difficult in 1st. What would be a good stall for my street ride? Thanks
10-20-2005 #2
Starting The Transformation
- Oct 2005
- SoCal
- 489
So with 450hp you can't spin the tires at all?
RPM range are you running in? I'm guessing 2500-6k max? What rpm does is peak torque made at?
What makes you think the 3k is too high?
Personally I favor a high stall converter on the street. My truck for instance makes just over 400rwhp N/A with 6200 rev limiter. With 3.92 gears, 29" tall tire, and weighing in at 4400lbs with me in it, i'm running a P.I. 3400 and it's my daily driver.
If it's too loose you might have it restalled to 2800 but personally i'd leave it alone. Sounds like you may have other problems too look at.
10-20-2005 #3
- Mar 2005
- 467
Example, WOT @ 6K in 1st, shift to 2nd- no spin, the motor has plenty of low end tq and power, est. peak tq 4500. The first converter was rated at approx max hp 450 but had a stall at prob. 2500 and could get the tires loose. This converter never seems to lock up solid except with OD. Motor hits fine, replaced clutch pack in tranny last convert change. rest of tranny good, rear end- no problems. My mechanic states that the converter is absorbing the tq and not transfering the power. The converter is from a reputable builder, 9.5" Precision Industries.
10-20-2005 #4
- Oct 2005
- SoCal
- 489
P.I. is the same setup i'm running, very nice converter from what I have seen.
Have you tryed calling them about it? Their tech support is very good and should be able to help you out.
The converter shouldn't "absorb" the torque at all. Does it feel soft when you nail the throttle from a stop? Like it stalls up then just takes off once you reach a certain rpm?
How firm does your trans shift? With peak torque at 4500 it should respond much better to the 3k stall than a 2.5k.
Dumb question, but have you checked the fluid level?
10-20-2005 #5
- Jul 2005
- Cumberland, Maryland
- 552
