    Results 1 to 7 of 7
      Salem, NH
      Water Pump Pulley bolts
      I apologize in advance for the dumb question. I'm converting to an electric fan so I no longer need the mechanical fan and spacer. The bolts that hold my water pump pulley on are too long. does anyone know where I can get a set of short bolts that will fit the thread of the stock waterpump flange for the pulley? If not, does anyone know the thread type so I can head to the hardware store? I'm hoping to get this done in time for this weekend.
      Thanks,
      Greg
      Jul 2002
      Mesquite, TX
      Greg, I don't have a specific answer for you other than "get grade 8 from the hardware store" (mainly because I'm at work) - but why not just take the old way-too-long bolt in with you? That way you could have a definitive "This is the right size/thread". Even if you're having to drive the project to the store, you could take the bolt out in the lot.
      May 2002
      Northern California
      its just 5/16" -20 or fine thread. just pick a length that wont bottom out on the pump
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      you could always take the cheap route out and cut down your existing bolts. then redo the 1st t hread on a bench grunder and your good to go
      Water pump studs ....you know the ones that hold on a clutch style fan."Help" section at local parts house.Remember they are FINE thread.
      Jun 2005
      San Jose, Ca.
      Quote Originally Posted by derekf
      I concur, you could get even get allen heads for a trick look. Don't forget the blue locktite and/or lock washers.
      Drowning in projects!
      Salem, NH
      Thanks guys, I ended up going with Maxoctane's suggestion. Stainless Allen heads with lock washers. 3/4 inch long 5/16 thread-24 fine thread.
