      Kiler wisconson
      Need fuel system help!! Part #s
      Im looking to upgrade my current fuel line and have never purchased AN fittings before..
      I need a fuel line and connectors to go from my holley street/strip pump to my carbs, and also i need something to replace my cheap chrome dual feed carb lines!
      what AN is closest to a 1/2 line..
      Part numbers would be great!
      I want the stainless fitting not the red and blue ones!
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      -8AN is plenty big and will support up to at least 600hp.
      http://www.russellperformance.com/au...ose_ends.shtml
      Price shop as you will be able to save a few dollars here and there depending on the brand.
      Holley sells a plain aluminum dual carb inlet. I have one on mine, but I cannot find the part.
      You can see the bottom in this pic.
      Kiler wisconson
      Will 8 an support 750hp? that is my goal.. Looks great..
      Project JUST-N-SANE
      Oct 2005
      SoCal
      Easy reference is 1 AN= 1/16" ID. So -8 is 1/2" and so forth.
      Are you still running a mechanical pump or a big electric?
      Check ebay, a lot of times you can find great deals on AN line/fittings but most of it is the regular red/blue.
      Jackson Ms
      to supply a dual feed carb i like to run an 8 an line from BOTH outlet ports on the regulator to the carb. they make the an fitting just for this. It look nice, supports more power, and cost about the same $$$$.
      Chris V
      SOLD
      Jackson Ms
      Quote Originally Posted by WELTERRACER
      i have read some of your past post and i know you are having some fuel problems. i cant remember what kind of times you are turning but i doubt you need a 750 HP fuel system. If you do them prepare to spend more on that then you did your engine rebuild. I have about 600 hp on motor and that is supported by a BG280 pump, 10 an lines, and a BG regulator. Now for the nitrous i have another BG280, 10 an lines, and another BG regulator.
      if you are running EFi then i would look at the A1000 and the matching regulator, and 8 an lines.
      Chris V
      SOLD
