Results 1 to 9 of 9
10-11-2005 #1
rear axle play in 8.2 BOP 10 bolt after installing rear disc brakes
I just finished a job, and part of it included doing a rear disc brake swap. The rearend in the car was a 8.2 pontiac 10 bolt. It had press in bearings. I popped the axles off(which took some force) and didn't have to touch the bearings to get off the drum backing plate and put on the disc brake bracket. PUt the axles back in and bolted everything together. The problem is that the axle will go in and out about 1/2" So getting the caliper moutned over the rotor is hard because the axle is moving in and out of the rearend. This was the first time I messed with a press in bearing rearend. Is something worn out or what the heck? thanks!
