    Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 41 to 60 of 130
    1. #41
      Apex, NC
      What size rear tire are you going to run?
    2. #42
      Port Richey Fl
      Brian wanted to see how 275 x 18's fit so he borrowed these from another project car
      This is the owners original 255 x 17's that are now to narrow and will be going on my Mustang II restomod under construction.
      Rusty Gillis
      Former SS/FA & SS/GA NHRA National Record Holder
    3. #43
      Port Richey Fl
      Quote Originally Posted by Crestronwizard View Post
      Probably 275 17 on the rear
      Rusty Gillis
    4. #44
      Sep 2015
      SW KS
      Quote Originally Posted by rusty428cj View Post
      Tell me more about this Mustang II. Perhaps its own thread.
      Chris
    5. #45
      Sep 2015
      Are you going to be running a stock width rear end?? Whats the offset on the wheels. Very motivating thread!!!!
      1966 Mustang Coupe
      5.0 EFI- T5
    6. #46
      Port Richey Fl
      Quote Originally Posted by rhurley View Post
      The rear will be stock width. We are going with Rod & Custom coilover rear suspension. We need to get it installed and we can measure for the offset.
      Rusty Gillis
    7. #47
      Port Richey Fl
      Sprayed a little epoxy to keep it from getting any surface rust
      Brian is starting on the other side. Bolted on the stone guard and front valance to keep everything lined up.
      Left side
      Welds ground
      Rusty Gillis
    8. #48
      Jun 2014
      Highland Village, TX
      Can't wait to see those pics. I run that suspension on the Mach1, still getting it dialed in. Love it so far.
      Ron -
      1970 Mach1
      440 RWHP, 428 RWTQ
      Calypso Coral, 357W, T5Z 5-speed,
      Edelbrock 454 17x8 Wheels, 255x40x17 rear, 215x45x17 front, Bridgestone Potenza RE-71, TCP Coilovers Front, Global West Del-A-Lum Bushings,Global West Adj. Strut Rods, Wilwood Discs All around
    9. #49
      May 2010
      British Columbia
      Your man sure knows what he's doing ! nice
    10. #50
      Port Richey Fl
      Currie 9" with Wilwood brakes
      Test fitting the rear suspension
      Rusty Gillis
    11. #51
      Port Richey Fl
      The original front fender flare has to be cut out
      The fenders were sanded to bare metal and epoxy primed
      We did a little bodywork on the inside of the fenders and epoxy primed
      Rusty Gillis
    12. #52
      Jan 2014
      Greenville NC
      Nice work!!
      1970 Mustang Convertible
      408w stroker
      TCI 6X
      Heidts Mustang II front, 4-Link rear, subframe connectors
      Custom SS exhaust, X-pipe, Spintech muffs.
      and more...much more!
    13. #53
      Apr 2010
      DC
      I never was really interested in putting flares on my car, but I've been changing over the last couple of months. I must say, those look exactly the way I'd do them if I do them. Can't wait to see them painted up on the finished car. How wide do you think you can go on the front?
    14. #54
      Apex, NC
      Looking good. I sprayed bedliner on the inside of my fenders.
    15. #55
      Port Richey Fl
      I have the second Rod & Custom rear suspension kit sold on my 1968 Coupe and it fit great. We can get the car real low if we want. The kit has been redesigned and it is a little harder to install and you cannot get it as low as my car.
      The upper shock mount now has heim joints because I'm sure not all early Mustangs have the same distance between the frame rails. Tack welded in place
      Upper control arm crossmember and rear end brackets tack welded in place
      Installing the rear coilover shocks
      Everything was installed according to the directions and this is the lowest it would go.
      After talking to Rod & Custom they said to turn the lower shock mount over
      This is the ride height now with no weight in the car
      Rusty Gillis
    16. #56
      Port Richey Fl
      With weight in the car I think the ride height will be about right
      Welded the rear valance in place
      Welds ground
      We wanted to do something different for the exhaust. We cut the exhaust outlets from a 1967 valance but had to make it a little larger to fit our tail pipes
      Welds ground
      Rusty Gillis
    17. #57
      Port Richey Fl
      Fixing the trunk gap
      The owner wanted a spoiler but did not like how tall it was so we lowered the Mustangs to Fear spoiler and end caps about 1". It will be straight with the top of the quarter
      Spoiler cut and test fitting
      Rusty Gillis
    18. #58
      Sep 2015
      SW KS
      Oh that lower spoiler will look really cool! Subtle touches all the way around will make this car look it should have come this way from the factory. Well done!
      Chris
    19. #59
      Port Richey Fl
      The end caps were bolted, bonded and fiberglass mat added to the quarter panel
      The spoiler was bonded to the deck lid and fiberglass mat added
      Rusty Gillis
    20. #60
      Dec 2011
      Rusty, looks fantastic, keep the updates coming.
