      Nov 2010
      which headers fit
      Which headers will fit a first gen fbody using hooker/Holley motor mounts and crossmember other than the hooker headers? Any style that fits an 98-02 fbody? Kooks? It is an LS2/t56 swap. Thanks
      Mar 2013
      Quote Originally Posted by firebirdzig View Post
      Hey firebirdzig, I wanted to point something out to you to save you considerable grief and aggravation in your project. Any non-Hooker long-tube header you attempt to install with the Hooker engine brackets will suffer from poor ground clearance due to the fact that they are all designed around the higher installed engine height that results from using the factory frame stands/mounts and LS swap plates. The Hooker engine brackets position the engine lower in the subframe than is possible with that mounting method and the Hooker headers are designed around that geometry to tuck the collectors tight to the floor. Conversely, if you tried to install the Hooker long-tubes on an engine installed with typical swap plates, the collectors wound be jammed up against the floor and you would not be able to get the flange bolts installed at the cylinder head.
      Nov 2010
      which headers fit
      Ah I see, guess you don't have much of a choice in this matter than.
      Mar 2013
      I'd say not if you are using the Hooker mounting components on a lowered car and are concerned with optimizing ground clearance. In case you've never seen the ground clearance provided by the Hooker long tubes and exhaust systems for this application, here's a side-shot image of the ceramic coated 1-7/8" headers and the 3" exhaust system. The headers are also available in 304ss if you want to go the premium route. If you go with mid-length headers or manifolds then you have a far great range of fitment compatibility.
      Todd
      Jul 2013
      San Fernando Valley
      I used the all the hooker/holley parts in my LS3/4l65e swap. Everything fits great. If you're already using the motor mounts I would use the hooker headers. They fit awesome and look real nice also.
      Jan 2014
      Sacramento, California
      With any swap setup its all designed to work around their parts so its easiest to do mounts, crossmember and headers all from the same company. thats why everyone offers them as kits now....speedtech, hooker, brp
