02-24-2015 #1
- Aug 2007
- 16
67 camaro problem removing quarter panel
I have a problem with the left front quarter panel bolt that is behind the door. The "nut" that is in the a pillar is spinning. I tried applying pressure behind the quarter panel the hold the nut in place enough to break the bolt loose but no luck. How do I get to that "nut" or clip. Can I get to it under the cowl? Eventually I will need to fix the problem to reinstall so I might as well tackle that now.
Thanks in advance.
