    Page 7 of 10 FirstFirst ... 2 3 4 5 6 7 8 9 10 LastLast
    Results 121 to 140 of 188
    1. #121
      Jan 2000
      Thousand Oaks California
      Trying not to break either of Susan's rules for the garage. Don't set anything on fire and don't blow anything up.
      Larry Callahan
    2. #122
      Jan 2000
      Mocking up the dash and center console again
      Larry Callahan
    3. #123
      Jan 2000
      Quote Originally Posted by Dewboy View Post
      Hi Larry,
      I love your build. I’m doing a build very close to yours. I have a 1969 Camaro with Art Morrison front and 4 link rear, LSA motor with 6L90E with Speartech controller. My engine should be here in early Feb. with the Trans.
      My question is, did you have to modify the front sub frame for the FEAD (Front Accessory Drive System)? Do you have any pictures up close of the engine setting in the sub frame that you can post?
      I’m going to start a Project Update as we get more things done to help other people doing a similar build.
      Dewboy
      We had to cut the engine mount tubes off the frame and move both of them. We also had to make custom mounting plates to bolt it in. I will take come pictures. Since I'm not certain but they might not be the same for you due to the different trans.
      I also had to change the oil pan.
      Larry Callahan
    4. #124
      Jan 2000
      MotiV8r update- Almost done installing the Design Engineering, Inc. Floor and Tunnel Shield II. This should really help keep the catalytic converter heat and exhaust heat out of the cabin. It's adhesive backed and pretty easy to form and install. Since the engine and trans is already in the car I can't utilize the adhesive everywhere so I added some stainless self drilling screws and stainless fender washers. This should hold up well to the autocross cones I will surely cram under the car once in a while.
      https://www.designengineering.com/ca...und-insulation
      Larry Callahan
    5. #125
      Jan 2000
      My dad finished machining the dash to hold the Racepak IQ3 Data logger display, the switch module for the Racepak Smartwire, the Pioneer NAV system and the Vintage Air vents. Now we need to make a couple of brackets for the back and cut the carbon fiber inserts.
      Larry Callahan
    6. #126
      Jan 2000
      And now I cut the dash.
      I hate fiberglass dust!
      This worked pretty good. It was surprisingly quiet and the exhaust dumped out at the end of the 2 foot hose and it didn't blow dust everywhere.
      Larry Callahan
    7. #127
      Mountain Springs, Texas
      Quote Originally Posted by Larry Callahan View Post
      This is a bit of a mystery to me. I did not have to modify my AME subframe for my LSA and I used the stock LSA oil pan and the AME engine mount plates. Stock LSA accessory drive fit with a minor alternator trim.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    8. #128
      Jan 2000
      That's a bit of a mystery to me as well.
      Are you also running the low mount air conditioning and does anything stick below the bottom of the frame?
      Larry Callahan
    9. #129
      I have a low mounted SD508 compressor with a modified VA/Alan Grove bracket. Nothing hangs below the frame except a skooch of the 6L90E pan. I did raise the tunnel for the 6L90e.
      Don
    10. #130
      Jan 2007
      CT
      I love the floor board/ trans tunnel insulation. How far up the firewall did you go? How much did you need to cover the bottom?
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
    11. #131
      The Netherlands
      Country Flag: Netherlands
      The dash is a real piece of art....can't wait to see it finished :-)
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
    12. #132
      Jan 2000
      Quote Originally Posted by nicks67camaro View Post
      I think I used less than two large sheets.
      I went up the firewall only to the top of the angle where your feet rest.
      Larry Callahan
    13. #133
      Jonesboro, Arkansas
      Hey Larry,
      Can I borrow your dad for a while?
      Carl Wilson
    14. #134
      Quote Originally Posted by minendrews68 View Post
      Hey Larry,
      LOL, X2.
      Don
    15. #135
      Oct 2015
      They are showing for me. Mind if I ask what software/browser you are using? I will try to duplicate it.
      Hey Larry... sorry I didn't see this till now. Anyway, I'm able to view all of the pictures now... thanks and AWESOME build!!!
    16. #136
      Oct 2013
      Larry,
      How are you going to make the GM a/c compressor work with the Vintage air unit?
      According V.A. the Gm a/c compressor is the wrong type of compressor. I have the same dilemma?
      Dewboy
    17. #137
      Jan 2000
      Larry,
      How are you going to make the GM a/c compressor work the Vintage air unit?
      Dewboy
      I did some research and the compressor that comes from Chevrolet Performance is a fixed displacement unit. It is slightly smaller in displacement than Vintage Air recommends but I will go for it.
      Larry Callahan
    18. #138
      Oct 2013
      Thanks, keep us posted on the A/C issue.
    19. #139
      May 2001
      Mesa, Az.
      Yes there are many GM OEM Fixed Displacement compressors. I once saw a list on LS1 tech. Cannot find it at the moment though.
      Phillip
    20. #140
      Jan 2000
      Making some progress on MotiV8r.
      The dash insert is almost complete. I need to mount the RacePak IQ3s Street dash and make some new light and wiper knobs.
      Larry Callahan
