    Page 4 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 188
    1. #61
      Anything new with MotiV8r Larry?
    2. #62
      Jan 2000
      Thousand Oaks California
      It's time for a little MotiV8r update. Today I stopped by JCG in Oxnard to chat with Cris and drop off some parts. They have made a recess in the firewall to mount the ABS pump, mounted the new dash, hung the Gen IV Magnum Vintage Air evaporator and prepared the dash for my new Ididit tilt column. I had it built with a high/low beam control arm, an ignition switch that I can reach when I'm harnessed in and for future use I had them install a cruise control arm as well. I also dropped off my Classic Truck Consoles center column and a heated and chilled cup holder. Once the trans tunnel is cut out they will weld in the new Bolwer Transmissions trans tunnel and I will get busy wiring it. It's moving along nicely now!
      Larry Callahan
    3. #63
      Dec 2010
      Fredericksburg, VA.
      With such a clean firewall, I'm surprised you aren't using the RainGear hidden wiper system.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    4. #64
      Jan 2000
      The Detroit Speed Selecta-speed unit I installed in 2008 works well and it's already there. With 7 speeds and 5 delays I'm really happy with it.
      Larry Callahan
    5. #65
      Jan 2000
      Whoa!!!!! Braking system video 1 of 2
      In this video we show you the awesome Wilwood Brake system that we are installing in MotiV8r to bring the speeds down. It doesn't matter how much horsepower you have or how fast your car is if you can't reliably slow it down or stop it. Upgrading your brakes should always be a main priority when upgrading a car.
      Larry Callahan
    6. #66
      Jan 2000
      Recently I stopped by JCG in Oxnard to drop off some parts and check out the progress on the Bowler Performance Transmissions trans tunnel for first gen Camaros. It's a nice weld in piece that comes with the trans tunnel and the short piece that goes up the firewall. They are nice and thick and have the strengthening ribs on them as well. Once everything is trimmed to fit and welded in we will post more pictures.
      For more info or to order one for yourself visit Bowler Performance Transmissions (who also sells stick shifts) at http://bowlertransmissions.com/
      Below is an update. I need to move the NAV system to the right a bit. It's being covered by the steering wheel.
      Larry Callahan
    7. #67
      Jan 2000
      I'm also working with JCG on the dash insert for MotiV8r. The current thought is below. It will be an aluminum plate with my Racepak IQ3 Data logger dash, the Pioneer stereo/navigation system, Vintage Air control and air conditioning vents.
      Larry Callahan
    8. #68
      Oct 2007
      Union Mo
      That dash is sweet
    9. #69
      Charlotte
      Very cool - I just watched all the Motivator LSA videos on YouTube - nice information clips!
      Are you using the stock LSA front accessory drive?
      That AC belt looks like a PITA to install - especially if the motor was in the car. On my LS2 there is a tensioner on there - and it slips on and off with ease.
      Do you have a coolant reservoir for the blower intercooler picked out yet?
      2014 Chevy SS LS3 / 4 Door
    10. #70
      Jan 2000
      Quote Originally Posted by bonecrrusher View Post
      Thanks for watching! It is the stock GM accesory drive but it's not the exact thing from a CTS-V. I think some of the components are located in different places. You can order from Chevrolet Performance or many of the big online parts companies.
      For the coolant reservoir I ordered the stock CTS-V unit. I'm trying to use as most OEM stuff as I can. I'll find it an post a picture of it soon.
      Larry Callahan
    11. #71
      Jan 2000
      My Chevrolet Performance LSA E-Rod crate engine ships with the oil pan for a Cadillac CTS-V.
      While it's a bulletproof pan and you should use it if you can I can't. It won't clear my Art Morrison sub frame. So, after some internet searching and talking to Cris at JCG I decided to go with a GM F-Body oil pan from a 1998-2003 Camaro or Firebird. GM Part # 12628771
      I also ordered a trap door baffle kit from Improved Racing to the the oil where it needs to be.
      I also ordered up a K&N oil filter Part # HP-1017. It's a great filter and I LOVE the welded on hex to put a wrench on
      Since my C&R radiator has a built in oil cooler I ordered or a Lingenfelter oil cooler adapter and installed that as well.
      When swapping out the pan I used the same sealer GM uses in the 4 corners to prevent an oil leak. You can get this stuff in a small tube like this or a cartridge for a caulking gun.
      While I had the pan off and I was installing the new pickup and windage tray I got to take a look at the piston oil squirters. That was kind of cool.
      So that's it for the engine changes. Now it's ready for the trans and for JCG to install it.
      Larry Callahan
    12. #72
      Looks good Larry, I have the same Lingenfelter oil cooler adapted for my LSA but my American Racing Headers put a header tube right between the oil adapter and the sensor you can see in your picture. The tube is only about 1/2" from the block. I think I'll need an adapter that points the hoses down and run them along the oil pan to the radiator.
    13. #73
      Jan 2000
      Shock time!
      I have decided to switch to a set of ridetech HQ monotube coilovers for MotiV8r. They are a great shock and I really look forward the better control they offer over the shocks we put on the car in 2008.
      Check out the video below and learn why.
      Larry Callahan
    14. #74
      Feb 2011
      dallas, tx
      Im running into issues with my wilwood proportion valve. Its too close to the fender. Im looking for something like this. Art morrison sells it
      http://www.artmorrison.com/uploads/wilwood-225.jpg
    15. #75
      Jan 2000
      I don't have any pictures of mine but it was mounted under the drivers seat on the side of the frame. This allowed me to open the door and reach under the car to make a change if needed.
      Larry Callahan
    16. #76
      Jan 2000
      It's time for an exciting MotiV8r update: Thursday evening I was able I drop off my Chevrolet Performance LSA E-Rod and T56 Super Magnum at JCG Restoration and Customs in Oxnard. Last week I received my trans install kit which includes a block plate, a dual mass, dual disc clutch /flywheel for the 8 bolt crank, a bellhousing/scatter shield along with the hydraulic throwout bearing and every nut and bolt you need to put it all together. Both the flywheel and bellhousing are SFI certified and have the appropriate stickers on them. It's truly a complete kit in a box and all this can be found at chevroletperformance.com
      Larry Callahan
    17. #77
      Great news Larry. Is the tunnel back in or are they waiting to put the motor and trans in?
    18. #78
      Mountain Springs, Texas
      The CTS-V pan on my LSA crate engine fit perfectly in my Art Morrison subframe. Are you using the AME mounts and plates etc?
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    19. #79
      Jan 2000
      We are waiting for the engine to be in place before we complete the Bowler trans tunnel.
      Larry Callahan
    20. #80
      Jan 2000
      Don
      That's great news and a bummer for me. I would have LOVED to have left the factory pan on it installed on the production line. I heard those pans and the pickup were bullet proof. I was told that it would not fit so I spent a bunch of time and money trying to replace it. Doh!!!
      Have you spent any time on a road course with it? Any oil starvation issues if you have?
      Larry Callahan
