    Results 1 to 7 of 7
      Procharger modifications ?
      hi all
      i have desided, it will be a PROCHARGER kit with a P-1SC charger.
      now my questions.
      my engine, a GMPP 330hp crate engine with a compression ratio from 9,6:1
      http://www.chevy-elcamino.com/technical.html
      must i lowered the compression for the charger to 8,5 ?
      i need a new carb ok, my speed-demon have vacuum secundary´s.
      make barry grant carbs for the charger ?
      all answers welcome
      greets
      Klaus
      Milwaukee, Wi.
      Klaus, you could exchange your head gaskets for some thicker ones to lower your compression. A CSU or similar carb would work best for a blow through setup.
      Good luck, Steve
      Dunwoody, GA
      if the engine has aluminum heads and you can get 92 or 93 octane fuel then you can run 6-7 lbs of boost with the procharger and be fine. of course the tuning must be right as well.
      Trey
      ~ Jon Hammond
      hi,
      thanks.
      no, my engine have vortec iron heads, not aluminium heads.
      i think i change the head gaskets for a 8.5:1 compression.
      the lowest fuel you can buy here in Luxembourg is the standart with 95 octane.
      greets
      Klaus
      Dunwoody, GA
      then yes i would lower the compression. I am not sure though if a change in gaskets will get you lower or not though. that is beyond my knowledge.
      Trey
      ~ Jon Hammond
      Kiler wisconson
      Get a thicker head gasket or buy a good intercooler and run no less than 93 octain..
      Project JUST-N-SANE
      84' Camaro Z-28, 355CID,9.0-1 compression, ATI procharger 9psi (over 650HP),T56 6 speed, 3.73 Motive gears! 11.70 at 122mph in the 1/4 while babying the throttle to keep the tires hooked ,with pump gas! (NOW INTERCOOLED)
      yeep, i will go back to the original head gaskets.
      the engine have original 9:1 ratio.
      greets
      Klaus
