      Let's talk grease guns
      I need to buy grease and a grease gun. I know nothing about either. Anybody got a favorite brand? Is a pneumatic gun necessary?
      jp
      ​John Parsons
      Red Deer, Alberta, Canada
      Don't buy a cheap grease gun thats for sure, Pump action is what I like. Specific grease.... Couldn't help ya there.
      -Matt
      Matt
      Instagram: Cst_koon
      Dec 2003
      lost
      Pneumatic guns are dangerous and break quite a bit. One of our fuel drivers just got back from 6 months off after a hose blew and pumped grease into is hand. Basic Lincoln pistol grips work great.
      Nov 2004
      Roanoke, VA
      I prefer the pistol grip also since it leaves one hand free to position the end of the hose onto the zerk fitting.
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Syclone
      Tow rig
      Rockford Illinois
      Lincoln or Plews
      We used lincolns where I used to work and they take a lot of abuse before they give up. I bought a Plews about 3 years ago for home and it has been a real nice gun too. I believe I bought the Plews at Pepboys. You can get Lincolns thru McMaster Carr I do believe or at most industrial shop supply stores.
      I would stay away from pneumatics unless you like problems or plan on filling large shaft bearings on machines.
      Jim Nilsen
      McMurdo Station, Antarctica
      I have been using Amsoil Synthetic grease for quite a while now. http://www.amsoil.com/storefront/glc.aspx I started using it before synthetics became popular, so there were no other common choices at the time. On our stock car which was a '75 Chevelle w/stock spindles we had to repack the front wheel bearings every 5 races or so with cheap grease. When we switched to the Amsoil we would run a full season (16 races) without touching them. I know that ball joints and tie rod ends don't see the high speeds and high heat that wheel bearings see, but I have had very good luck using it on everything that I have built in the last 12 years.
      R.J.
      OK, thanks all. I picked up a Lincoln pistol grip gun and a Mobil 1 synthetic grease cartridge tonight.
      jp
      ​John Parsons
