      Nov 2011
      Riverton, Wyo,
      Led park/turn wiring questions?
      I am doing some wiring on my headlights, park, turn and fog lamps. I have a set of oracle 7inch halo headlights with h4 bulbs. The halos have 2 wires + and -. I want them to come on like drl. Just like new cars, I have 2 fog lamps out of a newer gmc truck. I then ordered a dual color halo that goes inside the fog lamp. It is white and amber and has 3 wires a + and 2 - wires. The lights are triggered off ground wires. One ground is white the other amber.
      So here is what I am trying to do,
      Key on have halo in headlight that is white come on.
      White halo in fog lamp on.
      Turn on lights and have h4 bulb on and 2 halos headlight and fog light halo.
      Turn on turn signal and would either like to have white light go out and amber flash for turn signal or possible alternate white/amber, white/amber.
      The 3 wire deal screws me up a little. I thought it would be ground and 2 hot wires one for turn (amber) and one for drl (white).
      I wired a relay into trigger a ground for the white lamp yesterday, Just not sure how to trigger the amber throught a electronic flasher and cancel the white when amber is on.
      My only other idea would be to scratch plan A and order a single amber led halo for the fog lamp and just have the single halo in the headlight. Then still run a fog lamp triggered of it's own switch.
      Hope all this makes sense,
      Thanks for the help guys!
      Sounds like you're attempting something similar to my setup...
      See if this helps...
      http://www.lateral-g.net/forums/showthread.php4?t=44534
      1971 Camaro
