      Sep 2014
      LS1 Carb, Intake and MSD Setup-SOLD!
      Used LS carbureted intake and ignition system. I’ve had this setup on my 5.3 for approx. 2 summers and 6000 miles. Works great, I am updating to EFI.
      Included:
      -Edelbrock dual plane cathedral port intake
      -Speed Demon 750 mech. secondary carb
      -MSD 6010 ignition and harness: Crank sensor wiring extended approx 1’. Cheap plastic split loom replaced with high quality Techflex self-wrapping loom. Includes all timing pills. MSD was mounted inside the, never exposed to heat/vibration/moisture.
      -Moroso 14” air cleaner-painted in wrinkle black, could use a touch-up coat.
      Extras:
      -SS allen head intake mounting hardware
      -Edelbrock bracket for mounting throttle and trans kickdown cables
      -Serial to USB port cable to allow direct connection from the MSD to any USB port. MSD only comes with a serial-serial cable. (What is this 1996?!)
      -Custom -6AN/JIC dual carb feed line
      Asking $800 shipped OBO
      EVERYTHING SOLD!
      Mar 2014
      pm'd u
      Sep 2014
      To the top, make me an offer and thanks for looking.
      Feb 2011
      what type of mpg were you getting.
      Southern NJ
      with this fit under a factory cowl hood on a 1st gen?
