Results 21 to 27 of 27
Thread: Procharger or Vortech ?
Speedster--> Thanks for the info. I do plan on doing a low cost/low boost application to start, and then move onto larger amounts of boost as my funds allow.
I am looking more for the best fitting kit. I have heard nothing but good things about the Vortech "kit" , as it is pretty complete, and you dont have to deal with the Procharger bracket nightmares.
Would I be better off "putting togther" a kit for my application ? Such as a compressor from Vortech, a bracket and pullet setup from another company, carb. hat from another , etc... ?
I really am not a fan of the Vortech carb box thing...:bsjerk:
ProTeal55
1955 Chevy Bel-Air 2 Door Hardtop
Member: Half Fast Chicago
http://www.halffastchicago.com
01-08-2006 #2ProTeal55-
Which ever one you choose, I would get "the kit". Both companies did a lot of research on their systems - no reason for you to reinvent (and finance) it. I was originally going to use a Vortech YS Trim kit, but went a little crazy on the top end of the motor, so ended up with a cog drive Procharger F-2.
The only thing you might consider is going a little larger rather than smaller on blower size. That way there are no regrets if and when you want to "turn it up".
-BruceProject "Freebird"
01-08-2006 #3One more brain fart - if you do order a Vortech kit, get it without the "box" if you are using a true blow through carb. It is redundant. Then all you need is a hat.
Project "Freebird"
01-08-2006 #4
New to Pro-Touring
- Feb 2005
- 56
I totally agree, its alot cheaper to turn it up than it is to upgrade to a bigger blower....
Originally Posted by speedster
01-08-2006 #5SPEEDSTER---->
I need to upgrade my carb anyways, thus a new Blow-Thru carb will be needed. Plus, I realy cant stand the look of that Vortech box anyways. So that works out.
All about a polished carb hat...
What would be a good Vortech blower for simple amounts of boost to start, but give me some kinda room to grow in the future ? Something like a YS ?ProTeal55
01-08-2006 #6Not trying to hi-jack the thread, but I'm researching the same things as Klaus and ProTeal55. With a Vortech, how do you control the amount of boost? Is there a waste-gate included w/the kit?
Ahhh, nevermind I see it's via the pulley size.
http://www.vortechsuperchargers.com/...big_block.html
Dan
