10-10-2005 #1
- Dec 2004
- Crestview FL
- 276
Old 60amp to CS 180 amp conversion
I just switched out my old 63 amp alt for a new custom built CS style 180amp alt and I must have not wired somting correctly because I have no power anywhere in the car. There were 2 wires going into the old clip that clipped into the side of the old alt and 1 wire that connected to the battrie post on the back of the alt. One of the wires that clipped into the side then exited and went to the battrie connection on the back of the alt.. That was how the old sys was wired with no problems.. so this is how I have it now.. there is the battrie wire that goes to the back of the post and then the 1 orange wire that clips into the alt that I connected to the wire that was in the engine harness. I was told that this should be the signal wire. Well with that hooked up I have no power anywhere in the car.. The battrie has 11.8 volts in it so I know that there is some juice there so what am I doing wrong??? Don't they make a kit for this conversion somewhere?
