      Jun 2006
      Katy,TX
      What angle to check caster no X factor?
      I've seen some different conflicting angle to turn the front wheels to to not need a multiplication factor to get the caster 15 and 20 degrees. Whcih is correct?
      1965 GTO project car
      2004 Pulse Red GTO
      Jul 2013
      St Louis
      Per Marc at SC&C its 15
      Pontiac Powered 72 GTO
      Jun 2006
      Katy,TX
      Thanks I thought 15 was correct but someone else said 20 is also.
      2004 Pulse Red GTO
      Central CA USA
      At 15 degrees turn in and out, you multiply by 2.
      Here is a great reference: http://www.smartracingproducts.com/s...nal_update.pdf
